#include <FlipBookPluginPlugin.h>
FlipBookPluginPlugin () | |
const char * | GetPluginName () override |
Returns the name for this plugin. More... | |
const char * | GetPluginVersionString () override |
Returns the version for this plugin. More... | |
bool | GetRequiredOnServer () override |
Returns true if this plugin is required on the server. More... | |
bool | GetRequiredOnClient () override |
Returns true if this plugin is required on the client. More... | |
const char * | GetRequiredPlugins () override |
Returns a ';' separated list of plugin names required by this plugin. More... | |
const char * | GetDescription () override |
Returns a description of this plugin. More... | |
const char * | GetEULA () override |
Returns EULA for the plugin, if any. More... | |
void | GetBinaryResources (std::vector< std::string > &resources) override |
Provides access to binary resources compiled into the plugin. More... | |
QObjectList | interfaces () override |
Returns the list of ParaView-Interfaces provided by this plugin. More... | |
Public Member Functions inherited from vtkPVGUIPluginInterface | |
virtual | ~vtkPVGUIPluginInterface () |
vtkPVPlugin () | |
virtual | ~vtkPVPlugin () |
const char * | GetFileName () |
typedef bool(* | EULAConfirmationCallback) (vtkPVPlugin *) |
Type for EULAConfirmationCallback. More... | |
static bool | ImportPlugin (vtkPVPlugin *plugin) |
Used when import plugins programmatically. More... | |
static void | SetEULAConfirmationCallback (EULAConfirmationCallback callback) |
Get/Set the static callback to call to confirm EULA. More... | |
static EULAConfirmationCallback | GetEULAConfirmationCallback () |
void | SetFileName (const char *filename) |
Set the filename the plugin is loaded from, if any. More... | |
Definition at line 29 of file FlipBookPluginPlugin.h.
FlipBookPluginPlugin::FlipBookPluginPlugin | ( | ) |
inlineoverridevirtual |
Implements vtkPVPlugin.
Definition at line 59 of file FlipBookPluginPlugin.h.
Definition at line 65 of file FlipBookPluginPlugin.h.
Definition at line 71 of file FlipBookPluginPlugin.h.
Definition at line 77 of file FlipBookPluginPlugin.h.
Definition at line 83 of file FlipBookPluginPlugin.h.
Definition at line 89 of file FlipBookPluginPlugin.h.
Implements vtkPVGUIPluginInterface.
