Signals | Public Member Functions | Protected Member Functions | List of all members
pqCheckableHeaderView Class Reference
A convenience QHeaderView painted with a QCheckBox. More...
#include <pqCheckableHeaderView.h>
Inherits QHeaderView.
Signals
void checkStateChanged (int section) const
 This signal is emitted whenever the state of the section header checkbox changes. More...
 pqCheckableHeaderView (Qt::Orientation orientation, QWidget *parent=nullptr)
 Constructs the pqCheckableHeaderView class. More...
 ~pqCheckableHeaderView () override
QVariant getCheckState (int section)
 Get the checkstate of the header checkbox for the section. More...
void paintSection (QPainter *painter, const QRect &rect, int logicalIndex) const override
 Paint the header section. More...
void mousePressEvent (QMouseEvent *event) override
 Handle mouse press event on the header. More...
void updateModelCheckState (int section)
 Update the checkstate of all checkable items in the model based on the checkstate of the header checkbox. More...
This allows for providing a global checkbox when the model items are user checkable. The checkbox is painted per section with one of the three states (checked, partially checked, unchecked) depending on the check state of individual items. Currently used in pqTreeView.
pqCheckableHeaderView is flagged to be investigated for deprecation. pqHeaderView provides a much simpler and more model-view friendly implementation that relies on the QAbstractItemModel simply respecting Qt::CheckStateRole for the header. It is recommended that you update your code to use pqHeaderView instead.
Definition at line 31 of file pqCheckableHeaderView.h.
◆ pqCheckableHeaderView()
pqCheckableHeaderView::pqCheckableHeaderView ( Qt::Orientation  orientation,
QWidget *  parent = nullptr
Parameters
[in]orientationOrientation for the header.
[in]parentThe parent object
◆ ~pqCheckableHeaderView()
pqCheckableHeaderView::~pqCheckableHeaderView ( )
override
◆ getCheckState()
QVariant pqCheckableHeaderView::getCheckState ( int  section)
Parameters
sectionThe section to get the checkstate of
◆ checkStateChanged
void pqCheckableHeaderView::checkStateChanged ( int  section) const
signal
The new state can be obtained using the getCheckState method.
Parameters
sectionThe section whose checkstate changed
See also
getCheckState
◆ paintSection()
void pqCheckableHeaderView::paintSection ( QPainter *  painter,
const QRect &  rect,
int  logicalIndex
) const
Depending on whether the top-level items in the model are checkable a checkbox is painted left-aligned on the header section. The checkbox is tristate and the state is decided based on the initial checkstates of model items. Reimplemented form QHeaderView::paintSection()
See also
◆ mousePressEvent()
void pqCheckableHeaderView::mousePressEvent ( QMouseEvent *  event)
Checks whether the mouse press was in the checkbox. Clicking on the checkbox triggers the checkStateChanged signal. Reimplemented from QWidget::mousePressEvent()
See also
QHeaderView::mousePressEvent
◆ updateModelCheckState()
void pqCheckableHeaderView::updateModelCheckState ( int  section)
This will undo any individual item checkstate modifications.
Parameters
sectionThe section whose model checkstate is updated.
