Public Types | Signals | Public Member Functions | List of all members
pqDelimitedTextParser Class Reference
Parses a delimited text file (e.g. More...
#include <pqDelimitedTextParser.h>
Inherits QObject.
enum  SeriesT { COLUMN_SERIES }
Signals
void startParsing ()
 Signal emitted when parsing begins. More...
void parseSeries (const QStringList &)
 Signal that will be emitted once for each data series contained in the parsed file. More...
void finishParsing ()
 Signal emitted when parsing ends. More...
 pqDelimitedTextParser (SeriesT series, char delimiter)
 Initializes the parser with the delimiter that will be used to separate fields on the same line within parsed files. More...
void parse (const QString &path)
 Call this to parse a filesystem file. More...
a CSV or tab-delimited file), and emits signals that represent data series from the file.
To use it, create an instance of pqDelimitedTextParser, passing the delimiter character in the constructor. Then, connect the startParsing(), parseSeries(), and finishParsing() signals to slots. Call parse() with the filename of the file to be parsed, and the parseSeries() signal will be emitted for each series of values contained within the file.
Definition at line 26 of file pqDelimitedTextParser.h.
◆ SeriesT
Enumerator
COLUMN_SERIES
Data series are organized in columns.
Definition at line 31 of file pqDelimitedTextParser.h.
◆ pqDelimitedTextParser()
pqDelimitedTextParser::pqDelimitedTextParser ( SeriesT  series,
char  delimiter
◆ parse()
void pqDelimitedTextParser::parse ( const QString &  path)
◆ startParsing
void pqDelimitedTextParser::startParsing ( )
signal
◆ parseSeries
void pqDelimitedTextParser::parseSeries ( const QStringList &  )
signal
◆ finishParsing
void pqDelimitedTextParser::finishParsing ( )
signal
