pqDesktopServicesReaction can be used to open a file (or URL) using QDesktopServices. More...
#include <pqDesktopServicesReaction.h>
pqDesktopServicesReaction (const QUrl &url, QAction *parent) | |
~pqDesktopServicesReaction () override | |
pqReaction (QAction *parent, Qt::ConnectionType type=Qt::AutoConnection) | |
Constructor. More... | |
~pqReaction () override | |
QAction * | parentAction () const |
Provides access to the parent action. More... | |
static bool | openUrl (const QUrl &url) |
Attempt to open a file (local or on the Web) using QDesktopServices. More... | |
void | onTriggered () override |
Called when the action is triggered. More... | |
virtual void | updateEnableState () |
virtual void | updateMasterEnableState (bool) |
bool | IsMaster |
e.g. if your application wants to launch a PDF viewer to open the application's User Guide, you can hookup a menu QAction to the pqDesktopServicesReaction. e.g.
The URL is set as status tip on the parent action.
Definition at line 24 of file pqDesktopServicesReaction.h.
pqDesktopServicesReaction::pqDesktopServicesReaction | ( | const QUrl & | url, |
QAction * | parent | ||
Returns false if failed to open for some reason, other returns true.
inlineoverrideprotectedvirtual |
Definition at line 40 of file pqDesktopServicesReaction.h.
