Public Member Functions | List of all members
pqFileDialogModel Class Reference
pqFileDialogModel allows remote browsing of a connected ParaView server's filesystem, as well as browsing of the local file system. More...
#include <pqFileDialogModel.h>
Inherits QAbstractItemModel.
 pqFileDialogModel (pqServer *server, QObject *Parent=nullptr)
 server is the server for which we need the listing. More...
 ~pqFileDialogModel () override
void setFileItemFlags (const Qt::ItemFlags &flags)
 set the flags for items of type file More...
void setDirectoryItemFlags (const Qt::ItemFlags &flags)
 set the flags for items of type directory More...
void setCurrentPath (const QString &path)
 Set the path that the file dialog will display. More...
QString getCurrentPath ()
 Returns the path the the file dialog will display. More...
bool isHidden (const QModelIndex &)
 Return true if the file at the index is hidden. More...
bool isDir (const QModelIndex &) const
 Return true if the given row is a directory. More...
bool mkdir (const QString &dirname)
bool rmdir (const QString &dirname)
bool rename (const QString &oldname, const QString &newname)
bool fileExists (const QString &file, QString &fullpath)
 Returns whether the file exists also returns the full path, which could be a resolved shortcut. More...
bool dirExists (const QString &dir, QString &fullpath)
 Returns whether a directory exists also returns the full path, which could be a resolved shortcut. More...
bool dirIsEmpty (const QString &dir, QString &fullpath)
 Returns true if a directory exists and is empty also returns the full path, which could be a resolved shortcut. More...
QChar separator () const
 returns the path delimiter, could be \ or / depending on the platform this model is browsing More...
QString absoluteFilePath (const QString &)
 return the absolute path for this file More...
int fileType (const QString &)
 return the file type of a file More...
QStringList getFilePaths (const QModelIndex &)
 Returns the set of file paths associated with the given row (a row may represent one-to-many paths if grouping is implemented) this also resolved symlinks if necessary. More...
pqServerserver () const
 Returns the server that this model is browsing. More...
bool setData (const QModelIndex &idx, const QVariant &value, int role) override
 sets data (used by the view when editing names of folders) More...
int columnCount (const QModelIndex &) const override
 return the number of columns in the model More...
QVariant data (const QModelIndex &idx, int role) const override
 return the data for an item More...
QModelIndex index (int row, int column, const QModelIndex &) const override
 return an index from another index More...
QModelIndex parent (const QModelIndex &) const override
 return the parent index of an index More...
int rowCount (const QModelIndex &) const override
 return the number of rows under a given index More...
bool hasChildren (const QModelIndex &p) const override
 return whether a given index has children More...
QVariant headerData (int section, Qt::Orientation, int role) const override
 returns header data More...
Qt::ItemFlags flags (const QModelIndex &idx) const override
 returns flags for item More...
void setShowDetailedInfo (bool show)
 Get/Sets whether the dialog shows additional information about the files like modification time and file size. More...
bool isShowingDetailedInfo ()
void setGroupFiles (bool group)
 Get/Sets whether the dialog should group numbered files together into a single file when the sequencs numbers are replaced by ... More...
bool isGroupingFiles ()
To use, pass a new instance of pqServerFileDialogModel to pqFileDialog object.
See also
pqFileDialog
Definition at line 28 of file pqFileDialogModel.h.
◆ pqFileDialogModel()
pqFileDialogModel::pqFileDialogModel ( pqServer server,
QObject *  Parent = nullptr
if the server is nullptr, we get file listings locally
◆ ~pqFileDialogModel()
pqFileDialogModel::~pqFileDialogModel ( )
override
◆ setFileItemFlags()
void pqFileDialogModel::setFileItemFlags ( const Qt::ItemFlags &  flags)
◆ setDirectoryItemFlags()
void pqFileDialogModel::setDirectoryItemFlags ( const Qt::ItemFlags &  flags)
◆ setShowDetailedInfo()
void pqFileDialogModel::setShowDetailedInfo ( bool  show)
This information can be time consuming to display if the server has many files in one directory so it is not displayed by default.
◆ isShowingDetailedInfo()
bool pqFileDialogModel::isShowingDetailedInfo ( )
◆ setGroupFiles()
void pqFileDialogModel::setGroupFiles ( bool  group)
◆ isGroupingFiles()
bool pqFileDialogModel::isGroupingFiles ( )
◆ setCurrentPath()
void pqFileDialogModel::setCurrentPath ( const QString &  path)
◆ getCurrentPath()
QString pqFileDialogModel::getCurrentPath ( )
◆ isHidden()
bool pqFileDialogModel::isHidden ( const QModelIndex &  )
◆ isDir()
bool pqFileDialogModel::isDir ( const QModelIndex &  ) const
◆ mkdir()
bool pqFileDialogModel::mkdir ( const QString &  dirname)
◆ rmdir()
bool pqFileDialogModel::rmdir ( const QString &  dirname)
◆ rename()
bool pqFileDialogModel::rename ( const QString &  oldname,
const QString &  newname
◆ fileExists()
bool pqFileDialogModel::fileExists ( const QString &  file,
QString &  fullpath
◆ dirExists()
bool pqFileDialogModel::dirExists ( const QString &  dir,
QString &  fullpath
◆ dirIsEmpty()
bool pqFileDialogModel::dirIsEmpty ( const QString &  dir,
QString &  fullpath
◆ separator()
QChar pqFileDialogModel::separator ( ) const
◆ absoluteFilePath()
QString pqFileDialogModel::absoluteFilePath ( const QString &  )
◆ fileType()
int pqFileDialogModel::fileType ( const QString &  )
◆ getFilePaths()
QStringList pqFileDialogModel::getFilePaths ( const QModelIndex &  )
◆ server()
pqServer* pqFileDialogModel::server ( ) const
◆ setData()
bool pqFileDialogModel::setData ( const QModelIndex &  idx,
const QVariant &  value,
int  role
override
◆ columnCount()
int pqFileDialogModel::columnCount ( const QModelIndex &  ) const
override
◆ data()
QVariant pqFileDialogModel::data ( const QModelIndex &  idx,
int  role
) const
override
◆ index()
QModelIndex pqFileDialogModel::index ( int  row,
int  column,
const QModelIndex &
) const
override
◆ parent()
QModelIndex pqFileDialogModel::parent ( const QModelIndex &  ) const
override
◆ rowCount()
int pqFileDialogModel::rowCount ( const QModelIndex &  ) const
override
◆ hasChildren()
bool pqFileDialogModel::hasChildren ( const QModelIndex &  p) const
override
◆ headerData()
QVariant pqFileDialogModel::headerData ( int  section,
Qt::Orientation  ,
int  role
) const
override
returns header data
◆ flags()
Qt::ItemFlags pqFileDialogModel::flags ( const QModelIndex &  idx) const
override
