Public Slots | Signals | Public Member Functions | Properties | List of all members
pqIntRangeWidget Class Reference
a widget with a tied slider and line edit for editing a int property More...
#include <pqIntRangeWidget.h>
Inherits QWidget.
Public Slots
void setValue (int)
 set the value More...
void setMinimum (int)
void setMaximum (int)
Signals
void valueChanged (int)
 signal the value changed More...
void valueEdited (int)
 signal the value was edited this means the user is done changing text or the user is done moving the slider. More...
 pqIntRangeWidget (QWidget *parent=nullptr)
 constructor requires the proxy, property More...
 ~pqIntRangeWidget () override
int value () const
 get the value More...
int minimum () const
int maximum () const
void setDomain (vtkSMIntRangeDomain *domain)
Properties
int value
int minimum
int maximum
Definition at line 19 of file pqIntRangeWidget.h.
◆ pqIntRangeWidget()
pqIntRangeWidget::pqIntRangeWidget ( QWidget *  parent = nullptr)
◆ ~pqIntRangeWidget()
pqIntRangeWidget::~pqIntRangeWidget ( )
override
◆ value()
int pqIntRangeWidget::value ( ) const
get the value
◆ minimum()
int pqIntRangeWidget::minimum ( ) const
◆ maximum()
int pqIntRangeWidget::maximum ( ) const
◆ setDomain()
void pqIntRangeWidget::setDomain ( vtkSMIntRangeDomain domain)
◆ valueChanged
void pqIntRangeWidget::valueChanged ( int  )
signal
◆ valueEdited
void pqIntRangeWidget::valueEdited ( int  )
signal
It implies value was changed and editing has finished.
◆ setValue
void pqIntRangeWidget::setValue ( int  )
slot
set the value
◆ setMinimum
void pqIntRangeWidget::setMinimum ( int  )
slot
◆ setMaximum
void pqIntRangeWidget::setMaximum ( int  )
slot
Property Documentation
◆ value
readwrite
Definition at line 22 of file pqIntRangeWidget.h.
◆ minimum
readwrite
Definition at line 23 of file pqIntRangeWidget.h.
◆ maximum
readwrite
Definition at line 24 of file pqIntRangeWidget.h.
