Public Types | Signals | Public Member Functions | Protected Member Functions | List of all members
pqKeyEventFilter Class Reference
: A class to handle QKeyEvent in an eventFilter and send high level signals. More...
#include <pqKeyEventFilter.h>
Inherits QObject.
enum  KeyCategory {
  Accept, Reject, TextInput, Motion,
  Focus
 An enum for the key events categories. More...
Signals
void textChanged (int key)
 Emited on text key pressed, without modifier. More...
void accepted (bool modified)
 Emited on enter or return pressed modified is true if Shift is pressed. More...
void rejected ()
 Emited on Escape. More...
void motion (int key)
 Emited on a motion key was pressed. More...
void focusChanged ()
 Emited on Tab press. More...
 pqKeyEventFilter (QObject *parent)
 ~pqKeyEventFilter () override
void filter (QObject *monitored)
 install event filter on monitored object. More...
void forwardTypes (QObject *monitored, QList< int > types)
 Filter monitored object but still forward event that fall under the given type. More...
void forwardType (QObject *monitored, int type)
bool eventFilter (QObject *obj, QEvent *event) override
 Reimplemented to handled QKeyEvent. More...
: pqKeyEventFilter is a configurable class that reimplements eventFilter() and emit high level signals to communicate about key events.
This is specially useful when a container widget wants to know about key events regardless of which of its child receive the event.
Definition at line 26 of file pqKeyEventFilter.h.
◆ KeyCategory
Enumerator
Accept
Reject
TextInput
Motion
Focus
Definition at line 38 of file pqKeyEventFilter.h.
◆ pqKeyEventFilter()
pqKeyEventFilter::pqKeyEventFilter ( QObject *  parent)
◆ ~pqKeyEventFilter()
pqKeyEventFilter::~pqKeyEventFilter ( )
override
◆ filter()
void pqKeyEventFilter::filter ( QObject *  monitored)
◆ forwardTypes()
void pqKeyEventFilter::forwardTypes ( QObject *  monitored,
QList< int types
◆ forwardType()
void pqKeyEventFilter::forwardType ( QObject *  monitored,
int  type
◆ textChanged
void pqKeyEventFilter::textChanged ( int  key)
signal
Text keys:
  • numbers
  • letters
  • space
  • backspace
As defined by QChar::isLetterOrNumber and QChar::isSpace
◆ accepted
void pqKeyEventFilter::accepted ( bool  modified)
signal
◆ rejected
void pqKeyEventFilter::rejected ( )
signal
Emited on Escape.
◆ motion
void pqKeyEventFilter::motion ( int  key)
signal
Motion keys: the four arrows, home, end, page down and page up.
◆ focusChanged
void pqKeyEventFilter::focusChanged ( )
signal
reverse is true on Shift + Tab.
◆ eventFilter()
bool pqKeyEventFilter::eventFilter ( QObject *  obj,
QEvent *  event
