widget to show progress in a QStatusBar. More...
#include <pqProgressWidget.h>
Inherits QWidget.
Public Slots | |
void | setProgress (const QString &message, int value) |
Set the progress. More... | |
void | enableProgress (bool enabled) |
Enabled/disable the progress. More... | |
void | enableAbort (bool enabled) |
Enable/disable the abort button. More... | |
Signals | |
void | abortPressed () |
triggered with the abort button is pressed. More... | |
pqProgressWidget (QWidget *parent=nullptr) | |
~pqProgressWidget () override | |
QToolButton * | getAbortButton () const |
QToolButton * | abortButton () const |
Provides access to the abort button. More... | |
void | setReadyText (const QString &) |
Set the text to use by default when the progress bar is not enabled which typically corresponds to application not being busy. More... | |
const QString & | readyText () const |
void | setBusyText (const QString &) |
Set the text to use by default when the progress bar is enabled which typically corresponds to application being busy. More... | |
const QString & | busyText () const |
void | updateUI () |
request Qt to paint the widgets. More... | |
Protected Attributes | |
pqProgressWidgetLabel * | ProgressBar |
QToolButton * | AbortButton |
Properties | |
QString | readyText |
QString | busyText |
pqProgressWidget is a widget designed to be used in the QStatusBar of the application to show progress for time consuming tasks in the application.
pqProgressWidget is a replacement for QProgressBar. It has the following differences with QProgressBar.
Definition at line 32 of file pqProgressWidget.h.
pqProgressWidget::pqProgressWidget | ( | QWidget * | parent = nullptr | ) |
Use abortButton
instead.
Definition at line 45 of file pqProgressWidget.h.
Definition at line 50 of file pqProgressWidget.h.
void pqProgressWidget::setReadyText | ( | const QString & | ) |
Default value is empty.
Definition at line 59 of file pqProgressWidget.h.
void pqProgressWidget::setBusyText | ( | const QString & | ) |
Default value is "Busy".
Definition at line 69 of file pqProgressWidget.h.
Set the progress.
Progress must be enabled by calling 'enableProgress` otherwise this method will have no effect.
slot |
This is different from enabling/disabling the widget itself. This shows/hides the progress part of the widget.
slot |
signal |
Definition at line 98 of file pqProgressWidget.h.
Definition at line 99 of file pqProgressWidget.h.
readwrite |
Definition at line 36 of file pqProgressWidget.h.
readwrite |
Definition at line 37 of file pqProgressWidget.h.
