dialog to generate a number series More...
#include <pqSeriesGeneratorDialog.h>
Inherits QDialog.
Public Slots | |
void | resetRangeToDataRange () |
Reset the range to the data range. More... | |
pqSeriesGeneratorDialog (double min, double max, QWidget *parent=nullptr, Qt::WindowFlags f=Qt::WindowFlags()) | |
~pqSeriesGeneratorDialog () override | |
QVector< double > | series () const |
Returns the generated number series. More... | |
void | setDataRange (double dataMin, double dataMax, bool reset=false) |
Set the dataMin and dataMax on the dialog They will be used only if reset is true or if resetRangeToDataRange is called. More... | |
pqSeriesGeneratorDialog is a simple dialog that lets the user generate a series of numbers. Multiple series are supported including linear, logarithmic and geometric.
Definition at line 20 of file pqSeriesGeneratorDialog.h.
pqSeriesGeneratorDialog::pqSeriesGeneratorDialog | ( | double | min, |
double | max, | ||
QWidget * | parent = nullptr , |
Qt::WindowFlags | f = Qt::WindowFlags() |
QVector<double> pqSeriesGeneratorDialog::series | ( | ) | const |
slot |
