Public Slots | Signals | Public Member Functions | Protected Attributes | List of all members
pqServerConfigurationCollection Class Reference
pqServerConfigurationCollection maintains a serializable collection of server-configurations defined in pqServerConfiguration instances. More...
#include <pqServerConfigurationCollection.h>
Inherits QObject.
Public Slots
void removeUserConfigurations ()
 Remove all user configurations. More...
Signals
void changed ()
 fired when the collection is modified. More...
 pqServerConfigurationCollection (QObject *parent=nullptr)
 ~pqServerConfigurationCollection () override
bool loadContents (const QString &contents, bool mutable_configs)
 load a pvsc txt. More...
QString saveContents (bool only_mutable) const
 save the currently loaded configurations to a file. More...
bool load (const QString &filename, bool mutable_configs)
 load/save configurations from/to file. More...
bool save (const QString &filename, bool only_mutable)
bool saveNow ()
void addConfiguration (vtkPVXMLElement *configuration, bool mutable_config=true)
 Add a server configuration. More...
void addConfiguration (const pqServerConfiguration &)
void removeConfiguration (const QString &)
 remove a configuration given the name. More...
QList< pqServerConfigurationconfigurations () const
 returns the set of server-configurations. More...
QList< pqServerConfigurationconfigurations (const pqServerResource &selector) const
 returns the configurations matching the selector's host. More...
const pqServerConfigurationconfiguration (const char *configuration_name) const
 Returns a configuration with the given name. More...
QMap< QString, pqServerConfigurationConfigurations
During construction, this class attempts to read server-configurations from following locations:
The location marked as "User-specific servers" is the location where any server-configurations created/imported by user are saved. User can only modify the server-configurations loaded from this file. All others are treated as read-only configurations.
Definition at line 32 of file pqServerConfigurationCollection.h.
◆ pqServerConfigurationCollection()
pqServerConfigurationCollection::pqServerConfigurationCollection ( QObject *  parent = nullptr)
◆ ~pqServerConfigurationCollection()
pqServerConfigurationCollection::~pqServerConfigurationCollection ( )
override
◆ loadContents()
bool pqServerConfigurationCollection::loadContents ( const QString &  contents,
load a pvsc txt.
If mutable_configs==true, then the server-configurations loaded from this file can be edited by the user and get saved in "User-specific servers" configuration file at destruction.
◆ saveContents()
QString pqServerConfigurationCollection::saveContents ( bool  only_mutable) const
If only_mutable==true, only the configurations that were marked mutable are saved, otherwise all configurations are saved.
◆ load()
bool pqServerConfigurationCollection::load ( const QString &  filename,
◆ save()
bool pqServerConfigurationCollection::save ( const QString &  filename,
bool  only_mutable
◆ saveNow()
bool pqServerConfigurationCollection::saveNow ( )
◆ addConfiguration() [1/2]
void pqServerConfigurationCollection::addConfiguration ( vtkPVXMLElement configuration,
bool  mutable_config = true
◆ addConfiguration() [2/2]
void pqServerConfigurationCollection::addConfiguration ( const pqServerConfiguration )
◆ removeConfiguration()
void pqServerConfigurationCollection::removeConfiguration ( const QString &  )
◆ configurations() [1/2]
QList<pqServerConfiguration> pqServerConfigurationCollection::configurations ( ) const
◆ configurations() [2/2]
QList<pqServerConfiguration> pqServerConfigurationCollection::configurations ( const pqServerResource selector) const
◆ configuration()
const pqServerConfiguration* pqServerConfigurationCollection::configuration ( const char *  configuration_name) const
Returns nullptr when none is found.
◆ removeUserConfigurations
void pqServerConfigurationCollection::removeUserConfigurations ( )
slot
This deletes the user servers.pvsc file.
◆ changed
void pqServerConfigurationCollection::changed ( )
signal
◆ Configurations
QMap<QString, pqServerConfiguration> pqServerConfigurationCollection::Configurations
Definition at line 102 of file pqServerConfigurationCollection.h.
