Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
pqServerDisconnectReaction Class Reference
Reaction to disconnect from a server. More...
#include <pqServerDisconnectReaction.h>
Inheritance diagram for pqServerDisconnectReaction:
Collaboration diagram for pqServerDisconnectReaction:
 pqServerDisconnectReaction (QAction *parent)
 Constructor. More...
- Public Member Functions inherited from pqReaction
 pqReaction (QAction *parent, Qt::ConnectionType type=Qt::AutoConnection)
 ~pqReaction () override
QAction * parentAction () const
 Provides access to the parent action. More...
static void disconnectFromServer ()
 Disconnects from active server. More...
static bool disconnectFromServerWithWarning ()
 Disconnects from active server with a warning message to the user to confirm that active proxies will be destroyed, if any. More...
void onTriggered () override
 Called when the action is triggered. More...
pqTimer UpdateTimer
- Protected Attributes inherited from pqReaction
bool IsMaster
- Protected Slots inherited from pqReaction
virtual void updateEnableState ()
virtual void updateMasterEnableState (bool)
Definition at line 14 of file pqServerDisconnectReaction.h.
◆ pqServerDisconnectReaction()
pqServerDisconnectReaction::pqServerDisconnectReaction ( QAction *  parent)
Constructor.
Parent cannot be nullptr.
◆ disconnectFromServer()
static void pqServerDisconnectReaction::disconnectFromServer ( )
Note that this method is static. Applications can simply use this without having to create a reaction instance.
◆ disconnectFromServerWithWarning()
static bool pqServerDisconnectReaction::disconnectFromServerWithWarning ( )
Returns true if disconnect happened, false if not i.e. the user cancelled the operation.
◆ onTriggered()
void pqServerDisconnectReaction::onTriggered ( )
overrideprotectedvirtual
◆ UpdateTimer
pqTimer pqServerDisconnectReaction::UpdateTimer
Definition at line 47 of file pqServerDisconnectReaction.h.
