pqSpreadSheetViewDecorator adds decoration to a spread-sheet view.
#include <pqSpreadSheetViewDecorator.h>
Inherits QObject.
This includes widgets that allows changing the currently shown source/field etc. To use the decorator, simply instantiate a new decorator for every new instance of pqSpreadSheetView.
Definition at line 21 of file pqSpreadSheetViewDecorator.h.
◆ pqSpreadSheetViewDecorator()
◆ ~pqSpreadSheetViewDecorator()
pqSpreadSheetViewDecorator::~pqSpreadSheetViewDecorator |
◆ generateCellConnectivity()
bool pqSpreadSheetViewDecorator::generateCellConnectivity |
const |
These are linked to the corresponding properties on the SpreadsheetView proxy using a pqPropertyLinks instance.
◆ setGenerateCellConnectivity()
void pqSpreadSheetViewDecorator::setGenerateCellConnectivity |
bool |
◆ showFieldData()
bool pqSpreadSheetViewDecorator::showFieldData |
const |
◆ setShowFieldData()
void pqSpreadSheetViewDecorator::setShowFieldData |
bool |
◆ showSelectedElementsOnly()
bool pqSpreadSheetViewDecorator::showSelectedElementsOnly |
const |
◆ setShowSelectedElementsOnly()
void pqSpreadSheetViewDecorator::setShowSelectedElementsOnly |
bool |
◆ fieldAssociation()
int pqSpreadSheetViewDecorator::fieldAssociation |
const |
◆ setFieldAssociation()
void pqSpreadSheetViewDecorator::setFieldAssociation |
int |
◆ setPrecision()
void pqSpreadSheetViewDecorator::setPrecision |
int |
◆ setFixedRepresentation()
void pqSpreadSheetViewDecorator::setFixedRepresentation |
bool |
◆ allowChangeOfSource()
bool pqSpreadSheetViewDecorator::allowChangeOfSource |
const |
Returns whether the user should allowed to interactive change the source.
being shown in the view. true
by default.
◆ setAllowChangeOfSource()
void pqSpreadSheetViewDecorator::setAllowChangeOfSource |
bool |
val | ) |
Set whether the user should be allowed to change the source interactively.
◆ eventFilter()
bool pqSpreadSheetViewDecorator::eventFilter |
QObject * |
object, |
QEvent * |
e |
Reimplemented to handle copy to clipboard in CSV format.
◆ uiModified
void pqSpreadSheetViewDecorator::uiModified |
signal |
◆ onCurrentAttributeChange
void pqSpreadSheetViewDecorator::onCurrentAttributeChange |
int |
protectedslot |
Triggered when the field association attribute changed.
Enabled/disable buttons that apply only to a given attribute.
◆ currentIndexChanged
void pqSpreadSheetViewDecorator::currentIndexChanged |
pqOutputPort * |
protectedslot |
◆ showing
◆ displayPrecisionChanged
void pqSpreadSheetViewDecorator::displayPrecisionChanged |
int |
protectedslot |
◆ toggleFixedRepresentation
void pqSpreadSheetViewDecorator::toggleFixedRepresentation |
bool |
protectedslot |
◆ copyToClipboard
void pqSpreadSheetViewDecorator::copyToClipboard |
protectedslot |
◆ Spreadsheet
readwrite |
readwrite |
There properties are connected to the corresponding ServerManager properties on the SpreadsheetView proxy.
Definition at line 25 of file pqSpreadSheetViewDecorator.h.
◆ showFieldData
readwrite |
Definition at line 33 of file pqSpreadSheetViewDecorator.h.
readwrite |
Definition at line 34 of file pqSpreadSheetViewDecorator.h.
◆ fieldAssociation
readwrite |
Definition at line 36 of file pqSpreadSheetViewDecorator.h.
