virtual void | PrintSelf (ostream &os, vtkIndent indent) |
virtual void | SetBoxSize (double) |
virtual double | GetBoxSize () |
void | AddFileName (const char *) |
| Add/Remove files to read. More...
void | RemoveAllFileNames () |
virtual void | SetByteSwap (int) |
| Set/Get the endian-ness of the binary file. More...
virtual int | GetByteSwap () |
virtual void | SetTagSize (int) |
| When false (default) 32-bit tags are read from the file. More...
virtual int | GetTagSize () |
virtual void | SetLevel (int) |
| Sets the level of resolution. More...
virtual int | GetLevel () |
vtkMultiBlockDataSetAlgorithm * | NewInstance () const |
vtkMultiBlockDataSet * | GetOutput () |
vtkMultiBlockDataSet * | GetOutput (int) |
virtual int | ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
