virtual void | SetFieldArrayName (const char *) |
| Name of the field to display. More...
virtual char * | GetFieldArrayName () |
virtual void | SetPrefix (const char *) |
| Set the text prefix to display in front of the Field value. More...
virtual char * | GetPrefix () |
virtual void | SetPostfix (const char *) |
virtual char * | GetPostfix () |
virtual void | SetFormat (const char *) |
| Set the format to use when displaying the field value. More...
virtual char * | GetFormat () |
void | SetController (vtkMultiProcessController *) |
| Get/Set the controller to use. More...
virtual vtkMultiProcessController * | GetController () |
vtkTableAlgorithm * | NewInstance () const |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
vtkTable * | GetOutput () |
vtkTable * | GetOutput (int index) |
void | SetInputData (vtkDataObject *obj) |
void | SetInputData (int index, vtkDataObject *obj) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
