void | SetSelectionConnection (vtkAlgorithmOutput *algOutput) |
| Convenience method to specify the selection connection (2nd input port) More...
void | RemoveAllSelectionsInputs () |
| Removes all inputs from input port 1. More...
int | FillInputPortInformation (int port, vtkInformation *info) override |
void | ResetLabels () |
| Get/Set the label to display the input. More...
void | SetLabels (int index, const char *label) |
| vtkSetStdStringFromCharMacro (DefaultLabel) |
| Set/Get the default label used for data that isn't labelized by a selection. More...
| vtkGetCharFromStdStringMacro (DefaultLabel) |
vtkDataSetAlgorithm * | NewInstance () const |
vtkPolyData * | GetPolyDataOutput () |
vtkStructuredPoints * | GetStructuredPointsOutput () |
vtkImageData * | GetImageDataOutput () |
vtkStructuredGrid * | GetStructuredGridOutput () |
vtkUnstructuredGrid * | GetUnstructuredGridOutput () |
vtkRectilinearGrid * | GetRectilinearGridOutput () |
vtkDataSet * | GetOutput () |
vtkDataSet * | GetOutput (int) |
void | SetInputData (vtkDataSet *) |
void | SetInputData (int, vtkDataSet *) |
void | AddInputData (vtkDataSet *) |
void | AddInputData (int, vtkDataSet *) |
virtual int | ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
