vtkMTimeType | GetMTime () override |
| Get the last modified time of this filter. More...
| vtkSetSmartPointerMacro (CutFunction, vtkImplicitFunction) |
| Specify the implicit function to perform the cutting. More...
| vtkGetSmartPointerMacro (CutFunction, vtkImplicitFunction) |
void | SetOffsetValue (int i, double value) |
| Set/get a slice offset value at specified index i. More...
double | GetOffsetValue (int i) |
void | SetNumberOfOffsetValues (int number) |
| Set/get the number of slice offset values. More...
int | GetNumberOfOffsetValues () |
virtual void | SetLevelOfResolution (int) |
| Sets the level of resolution. More...
virtual int | GetLevelOfResolution () |
vtkDataObjectAlgorithm * | NewInstance () const |
virtual void | SetOutput (vtkDataObject *d) |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
