virtual void | SetRefinementMode (int) |
| Get/Set how the output refinement is to be determined. More...
virtual int | GetRefinementMode () |
virtual void | SetCenter (double, double, double) |
| Get/Set the center for the plane. More...
virtual void | SetCenter (double [3]) |
virtual double * | GetCenter () |
virtual void | GetCenter (double &, double &, double &) |
virtual void | GetCenter (double [3]) |
virtual void | SetNormal (double, double, double) |
| Get/Set the normal for the plane. More...
virtual void | SetNormal (double [3]) |
virtual double * | GetNormal () |
virtual void | GetNormal (double &, double &, double &) |
virtual void | GetNormal (double [3]) |
virtual void | SetBoundingBox (double, double, double, double, double, double) |
| Get/Set the bounding box for the plane. More...
virtual void | SetBoundingBox (double [6]) |
virtual double * | GetBoundingBox () |
virtual void | GetBoundingBox (double &, double &, double &, double &, double &, double &) |
virtual void | GetBoundingBox (double [6]) |
virtual void | SetResolution (int) |
| Specify the resolution of the plane. More...
virtual int | GetResolution () |
virtual void | SetCellSize (double) |
| Specify the cell-size of the plane. More...
virtual double | GetCellSize () |
virtual void | SetPadding (double) |
| Specify the padding to use along each of the directions. More...
virtual double | GetPadding () |
vtkPolyDataAlgorithm * | NewInstance () const |
vtkPolyData * | GetPolyDataInput (int port) |
vtkPolyData * | GetOutput () |
vtkPolyData * | GetOutput (int) |
virtual void | SetOutput (vtkDataObject *d) |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
