virtual void | SetRefinementMode (int) |
| Get/Set how the output refinement is to be determined. More...
virtual int | GetRefinementMode () |
virtual void | SetOrigin (double, double, double) |
| Get/Set the origin or translation for the unit volume. More...
virtual void | SetOrigin (double [3]) |
virtual double * | GetOrigin () |
virtual void | GetOrigin (double &, double &, double &) |
virtual void | GetOrigin (double [3]) |
virtual void | SetScale (double, double, double) |
| Get/Set the scale factor for a unit volume. More...
virtual void | SetScale (double [3]) |
virtual double * | GetScale () |
virtual void | GetScale (double &, double &, double &) |
virtual void | GetScale (double [3]) |
virtual void | SetResolution (int, int, int) |
| Get/Set the output image resolution. More...
virtual void | SetResolution (int [3]) |
virtual int * | GetResolution () |
virtual void | GetResolution (int &, int &, int &) |
virtual void | GetResolution (int [3]) |
virtual void | SetCellSize (double) |
| Specify the cell-size of the output image. More...
virtual double | GetCellSize () |
virtual void | SetPadding (double) |
| Specify the padding to use along each of the directions. More...
virtual double | GetPadding () |
vtkImageAlgorithm * | NewInstance () const |
vtkImageData * | GetOutput () |
vtkImageData * | GetOutput (int) |
virtual void | SetOutput (vtkDataObject *d) |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
vtkImageData * | GetImageDataInput (int port) |
virtual void | AddInputData (vtkDataObject *) |
virtual void | AddInputData (int, vtkDataObject *) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
