vtkCPBaseFieldBuilder Class Referenceabstract
Abstract class for specifying fields over grids. More...
#include <vtkCPBaseFieldBuilder.h>
Inheritance diagram for vtkCPBaseFieldBuilder:
Collaboration diagram for vtkCPBaseFieldBuilder:
virtual void BuildField (unsigned long TimeStep, double Time, vtkDataSet *Grid)=0
 Return a grid. More...
static vtkCPBaseFieldBuilderSafeDownCast (vtkObject *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkCPBaseFieldBuilder ()
 Return the highest order of discretization of the field. More...
 ~vtkCPBaseFieldBuilder () override
Abstract class for specifying fields over grids for a test driver. May want to remove GetHighestFieldOrder as it is just a place holder for now.
Definition at line 20 of file vtkCPBaseFieldBuilder.h.
Definition at line 23 of file vtkCPBaseFieldBuilder.h.
◆ vtkCPBaseFieldBuilder()
vtkCPBaseFieldBuilder::vtkCPBaseFieldBuilder ( )
virtual unsigned int GetHighestFieldOrder() = 0;
◆ ~vtkCPBaseFieldBuilder()
vtkCPBaseFieldBuilder::~vtkCPBaseFieldBuilder ( )
virtual const char* vtkCPBaseFieldBuilder::GetClassName ( )
static int vtkCPBaseFieldBuilder::IsTypeOf ( const char *  type)
virtual int vtkCPBaseFieldBuilder::IsA ( const char *  type)
Reimplemented in vtkCPFieldBuilder, vtkCPCellFieldBuilder, and vtkCPNodalFieldBuilder.
static vtkCPBaseFieldBuilder* vtkCPBaseFieldBuilder::SafeDownCast ( vtkObject o)
void vtkCPBaseFieldBuilder::PrintSelf ( ostream &  os,
◆ BuildField()
virtual void vtkCPBaseFieldBuilder::BuildField ( unsigned long  TimeStep,
double  Time,
vtkDataSet Grid
pure virtual
Return a grid.
BuiltNewField is set to 0 if the grids that were returned were already built before. vtkCPBaseFieldBuilder will also delete the grid.
Implemented in vtkCPFieldBuilder, vtkCPCellFieldBuilder, and vtkCPNodalFieldBuilder.
