vtkChartWarning Class Reference
a vtkContextItem that draws a block (optional label). More...
#include <vtkChartWarning.h>
Inheritance diagram for vtkChartWarning:
Collaboration diagram for vtkChartWarning:
typedef vtkBlockItem Superclass
- Public Types inherited from vtkBlockItem
typedef vtkContextItem Superclass
- Public Types inherited from vtkContextItem
typedef vtkAbstractContextItem Superclass
- Public Types inherited from vtkAbstractContextItem
bool Paint (vtkContext2D *painter) override
 Paint event for the item. More...
bool Hit (const vtkContextMouseEvent &mouse) override
 Returns true if the supplied x, y coordinate is inside the item. More...
virtual void SetTextPad (double)
virtual double GetTextPad ()
- Public Member Functions inherited from vtkBlockItem
vtkBlockItemNewInstance () const
virtual bool MouseEnterEvent (const vtkContextMouseEvent &mouse)
virtual bool MouseMoveEvent (const vtkContextMouseEvent &mouse)
virtual bool MouseLeaveEvent (const vtkContextMouseEvent &mouse)
virtual bool MouseButtonPressEvent (const vtkContextMouseEvent &mouse)
virtual bool MouseButtonReleaseEvent (const vtkContextMouseEvent &mouse)
virtual void SetLabel (const vtkStdString &label)
virtual vtkStdString GetLabel ()
void SetScalarFunctor (double(*scalarFunction)(double, double))
virtual void SetDimensions (float, float, float, float)
virtual void SetDimensions (float[4])
virtual floatGetDimensions ()
virtual void GetDimensions (float &, float &, float &, float &)
virtual void GetDimensions (float[4])
- Public Member Functions inherited from vtkContextItem
vtkContextItemNewInstance () const
virtual double GetOpacity ()
virtual void SetOpacity (double)
- Public Member Functions inherited from vtkAbstractContextItem
vtkAbstractContextItemNewInstance () const
virtual void Update ()
virtual bool PaintChildren (vtkContext2D *painter)
virtual void ReleaseGraphicsResources ()
unsigned int AddItem (vtkAbstractContextItem *item)
bool RemoveItem (vtkAbstractContextItem *item)
bool RemoveItem (unsigned int index)
vtkAbstractContextItemGetItem (unsigned int index)
unsigned int GetItemIndex (vtkAbstractContextItem *item)
unsigned int GetNumberOfItems ()
void ClearItems ()
unsigned int Raise (unsigned int index)
unsigned int Lower (unsigned int index)
virtual vtkAbstractContextItemGetPickedItem (const vtkContextMouseEvent &mouse)
virtual bool MouseDoubleClickEvent (const vtkContextMouseEvent &mouse)
virtual bool MouseWheelEvent (const vtkContextMouseEvent &mouse, int delta)
virtual bool KeyPressEvent (const vtkContextKeyEvent &key)
virtual bool KeyReleaseEvent (const vtkContextKeyEvent &key)
virtual void SetScene (vtkContextScene *scene)
virtual void SetParent (vtkAbstractContextItem *parent)
virtual vtkVector2f MapToParent (const vtkVector2f &point)
virtual vtkVector2f MapFromParent (const vtkVector2f &point)
virtual vtkVector2f MapToScene (const vtkVector2f &point)
virtual vtkVector2f MapFromScene (const vtkVector2f &point)
virtual unsigned int StackAbove (unsigned int index, unsigned int under)
virtual unsigned int StackUnder (unsigned int child, unsigned int above)
vtkContextSceneGetScene ()
vtkAbstractContextItemGetParent ()
virtual bool GetVisible ()
virtual void SetVisible (bool)
virtual bool GetInteractive ()
virtual void SetInteractive (bool)
static vtkChartWarningNew ()
static vtkChartWarningSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkBlockItem
static vtkBlockItemSafeDownCast (vtkObjectBase *o)
static vtkBlockItemNew ()
- Static Public Member Functions inherited from vtkContextItem
static vtkContextItemSafeDownCast (vtkObjectBase *o)
- Static Public Member Functions inherited from vtkAbstractContextItem
static vtkAbstractContextItemSafeDownCast (vtkObjectBase *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkChartWarning ()
 ~vtkChartWarning () override
bool ArePlotsImproperlyScaled (vtkChart *)
- Protected Member Functions inherited from vtkBlockItem
 vtkBlockItem ()
 ~vtkBlockItem ()
- Protected Member Functions inherited from vtkContextItem
 vtkContextItem ()
 ~vtkContextItem ()
- Protected Member Functions inherited from vtkAbstractContextItem
 vtkAbstractContextItem ()
 ~vtkAbstractContextItem ()
double TextPad
- Protected Attributes inherited from vtkBlockItem
float Dimensions [4]
vtkStdString Label
bool MouseOver
double(* scalarFunction )(double, double)
- Protected Attributes inherited from vtkContextItem
double Opacity
- Protected Attributes inherited from vtkAbstractContextItem
vtkContextSceneScene
vtkAbstractContextItemParent
vtkContextScenePrivateChildren
bool Visible
bool Interactive
This is a vtkContextItem that can be placed into a vtkContextScene. It draws a block of the given dimensions, and reacts to mouse events.
Definition at line 22 of file vtkChartWarning.h.
Definition at line 26 of file vtkChartWarning.h.
◆ vtkChartWarning()
vtkChartWarning::vtkChartWarning ( )
◆ ~vtkChartWarning()
vtkChartWarning::~vtkChartWarning ( )
static vtkChartWarning* vtkChartWarning::New ( )
virtual const char* vtkChartWarning::GetClassName ( )
static int vtkChartWarning::IsTypeOf ( const char *  type)
virtual int vtkChartWarning::IsA ( const char *  type)
Reimplemented from vtkBlockItem.
static vtkChartWarning* vtkChartWarning::SafeDownCast ( vtkObject o)
void vtkChartWarning::PrintSelf ( ostream &  os,
◆ Paint()
bool vtkChartWarning::Paint ( vtkContext2D painter)
◆ Hit()
bool vtkChartWarning::Hit ( const vtkContextMouseEvent mouse)
◆ SetTextPad()
virtual void vtkChartWarning::SetTextPad ( double  )
◆ GetTextPad()
virtual double vtkChartWarning::GetTextPad ( )
◆ ArePlotsImproperlyScaled()
bool vtkChartWarning::ArePlotsImproperlyScaled ( vtkChart )
◆ TextPad
double vtkChartWarning::TextPad
Definition at line 48 of file vtkChartWarning.h.
