| vtkClientServerInterpreter (const vtkClientServerInterpreter &)=delete |
vtkClientServerInterpreter & | operator= (const vtkClientServerInterpreter &)=delete |
int | ProcessOneMessage (const vtkClientServerStream &css, int message) |
| Process the message with the given index in the given stream. More...
const vtkClientServerStream * | GetMessageFromID (vtkClientServerID id) |
| Get the message for an ID. More...
const vtkClientServerStream & | GetLastResult () const |
| Get the last result message. More...
vtkObjectBase * | GetObjectFromID (vtkClientServerID id) |
| Return a pointer to a vtkObjectBase for an ID whose message contains only the one object. More...
vtkObjectBase * | GetObjectFromID (vtkClientServerID id, int noerror) |
vtkClientServerID | GetIDFromObject (vtkObjectBase *key) |
| Return an ID given a pointer to a vtkObjectBase (or 0 if object is not found) More...
int | NewInstance (vtkObjectBase *obj, vtkClientServerID id) |
| Called by generated code to register a new class instance. More...
VTK_NEWINSTANCE vtkObjectBase * | NewInstance (const char *classname) |
| Creates a new instance for the class specified using the interpreter. More...
int | NewObserver (vtkObject *obj, const char *event, const vtkClientServerStream &css) |
| Called by generated code to add an observer to a wrapped object. More...
void | AddCommandFunction (const char *cname, vtkClientServerCommandFunction func, void *ctx=nullptr, vtkContextFreeFunction ctx_free=nullptr) |
| Add a command function for a class. More...
bool | HasCommandFunction (const char *cname) |
| Return true if the classname has a command function, false otherwise. More...
int | CallCommandFunction (const char *classname, vtkObjectBase *ptr, const char *method, const vtkClientServerStream &msg, vtkClientServerStream &result) |
| Call a command function. More...
void | AddNewInstanceFunction (const char *cname, vtkClientServerNewInstanceFunction f, void *ctx=nullptr, vtkContextFreeFunction ctx_free=nullptr) |
| Add a function used to create new objects. More...
void | ClearLastResult () |
| Resets the LastResult stream. More...
vtkClientServerID | GetNextAvailableId () |
| Return the next available Id that can be used to create a new object. More...
int | ProcessStream (const unsigned char *msg, size_t msgLength) |
| Process all messages in a given vtkClientServerStream. More...
int | ProcessStream (const vtkClientServerStream &css) |
void | SetLogFile (const char *name) |
| Get/Set a stream to which an execution log is written. More...
virtual void | SetLogStream (ostream *ostr) |
virtual ostream * | GetLogStream () |
int | Load (const char *moduleName) |
| Dynamically load a wrapper module into the interpreter. More...
int | Load (const char *moduleName, const char *const *optionalPaths) |
virtual void | Modified () |
