This is composite animation player that can me made to play an animation using the active player.
void | SetNumberOfFrames (int val) |
| Forwarded to vtkSequenceAnimationPlayer. More...
virtual void | SetPlayMode (int) |
| Get/Set the play mode. More...
virtual int | GetPlayMode () |
void | AddTimeStep (double val) |
| Forwarded to vtkTimestepsAnimationPlayer. More...
void | RemoveAllTimeSteps () |
void | SetFramesPerTimestep (int val) |
void | SetStride (int _val) override |
| Forwarded to vtkTimestepsAnimationPlayer.and vtkSequenceAnimationPlayer. More...
void | Play (int dir=1) |
| Start playing the animation. More...
void | Stop () |
| Stop playing the animation. More...
int | IsInPlay () |
| Returns if the animation is currently playing. More...
virtual bool | GetInPlay () |
void | GoToNext () |
| Take the animation scene to next frame. More...
void | GoToPrevious () |
| Take animation scene to previous frame. More...
void | GoToFirst () |
| Take animation scene to first frame. More...
void | GoToLast () |
| Take animation scene to last frame. More...
virtual void | SetAnimationScene (vtkSMAnimationScene *) |
| Set the animation scene that is to be played by this player. More...
vtkSMAnimationScene * | GetAnimationScene () |
virtual void | SetLoop (bool) |
| Set to true to play the animation in a loop. More...
virtual bool | GetLoop () |
virtual int | GetStride () |
| Get/Set the stride value fot the animation player. More...
virtual void | Modified () |
| vtkCompositeAnimationPlayer () |
| ~vtkCompositeAnimationPlayer () override |
vtkAnimationPlayer * | GetActivePlayer () |
void | StartLoop (double starttime, double endtime, double curtime, double *playbackWindow) override |
| Delegated to the active animation player. More...
void | EndLoop () override |
double | GetNextTime (double currentime) override |
double | GetPreviousTime (double currenttime) override |
double | GoToNext (double start, double end, double currenttime) override |
double | GoToPrevious (double start, double end, double currenttime) override |
| vtkAnimationPlayer () |
| ~vtkAnimationPlayer () override |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
It provides API to add animation players and then set one of them as the active one.
Definition at line 20 of file vtkCompositeAnimationPlayer.h.
