combine multiple representations into one with only 1 representation active at a time. More...
#include <vtkCompositeRepresentation.h>
typedef vtkPVDataRepresentation | Superclass |
enum | { SkippedUpdateDataEvent = vtkCommand::UserEvent + 91, UpdateTimeChangedEvent } |
typedef vtkDataRepresentation | Superclass |
typedef vtkPassInputTypeAlgorithm | Superclass |
typedef vtkAlgorithm | Superclass |
enum | DesiredOutputPrecision |
int | ProcessViewRequest (vtkInformationRequestKey *request_type, vtkInformation *inInfo, vtkInformation *outInfo) override |
vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More... | |
void | SetVisibility (bool val) override |
Methods overridden to propagate to the active representation. More... | |
vtkPVDataRepresentation * | GetActiveRepresentation () |
Returns the active representation if valid. More... | |
void | SetSelectionConnection (vtkAlgorithmOutput *input) |
Set the selection connection. More... | |
void | MarkModified () override |
Propagate the modification to all internal representations. More... | |
vtkDataObject * | GetRenderedDataObject (int port) override |
Returns the data object that is rendered from the given input port. More... | |
vtkStringArray * | GetRepresentationTypes () |
Returns the list of available representation types as a string array. More... | |
virtual void | AddRepresentation (const char *key, vtkPVDataRepresentation *repr) |
Add/Remove representations. More... | |
virtual void | RemoveRepresentation (vtkPVDataRepresentation *repr) |
virtual void | RemoveRepresentation (const char *key) |
void | SetActiveRepresentation (const char *key) |
Set the active key. More... | |
const char * | GetActiveRepresentationKey () |
void | SetInputConnection (int port, vtkAlgorithmOutput *input) override |
Overridden to simply pass the input to the internal representations. More... | |
void | SetInputConnection (vtkAlgorithmOutput *input) override |
void | AddInputConnection (int port, vtkAlgorithmOutput *input) override |
void | AddInputConnection (vtkAlgorithmOutput *input) override |
void | RemoveInputConnection (int port, vtkAlgorithmOutput *input) override |
void | RemoveInputConnection (int port, int idx) override |
void | SetUpdateTime (double time) override |
Passed on to internal representations as well. More... | |
void | SetForceUseCache (bool val) override |
void | SetForcedCacheKey (double val) override |
virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
Initialize the representation with an identifier range so each internal representation can own a unique ID. More... | |
unsigned int | GetUniqueIdentifier () |
Return 0 if the Initialize() method was not called otherwise a unique ID that will be shared across the processes for that same object. More... | |
virtual bool | GetVisibility () |
virtual vtkDataObject * | GetRenderedDataObject (int vtkNotUsed(port)) |
double | GetCacheKey () const |
Returns the cache-key the representation is currently using. More... | |
vtkAlgorithmOutput * | GetInternalOutputPort () override |
Retrieves an output port for the input data object at the specified port and connection index. More... | |
vtkAlgorithmOutput * | GetInternalOutputPort (int port) override |
vtkAlgorithmOutput * | GetInternalOutputPort (int port, int conn) override |
vtkView * | GetView () const |
Provides access to the view. More... | |
vtkMTimeType | GetPipelineDataTime () |
Returns the timestamp when RequestData was executed on the representation. More... | |
bool | GetNeedsUpdate () |
Returns true if the representation needs an update. More... | |
virtual void | SetArrayIdNames (const char *vtkNotUsed(pointArray), const char *vtkNotUsed(cellArray)) |
Specify the array names used for the selection. More... | |
virtual double | GetUpdateTime () |
Set the update time. More... | |
virtual bool | GetUpdateTimeValid () |
Get whether the UpdateTime is valid. More... | |
void | ResetUpdateTime () |
virtual double | GetForcedCacheKey () |
Generally, caching is within the purview of the vtkPVView (and subclasses). More... | |
virtual bool | GetForceUseCache () |
bool | AddToView (vtkView *view) override |
Making these methods public. More... | |
bool | RemoveFromView (vtkView *view) override |
virtual void | SetLogName (const std::string &name) |
This is solely intended to simplify debugging and use for any other purpose is vehemently discouraged. More... | |
const std::string & | GetLogName () const |
virtual bool | GetHasTemporalPipeline () |
This flag indicates if the representation is for a temporal pipeline. More... | |
virtual void | SetHasTemporalPipeline (bool) |
Overridden to ensure that MarkModified is called. More... | |
vtkDataRepresentation * | NewInstance () const |
virtual void | ApplyViewTheme (vtkViewTheme *vtkNotUsed(theme)) |
virtual vtkSelection * | ConvertSelection (vtkView *view, vtkSelection *selection) |
vtkAlgorithmOutput * | GetInputConnection (int port=0, int index=0) |
vtkAnnotationLink * | GetAnnotationLink () |
void | SetAnnotationLink (vtkAnnotationLink *link) |
void | Select (vtkView *view, vtkSelection *selection) |
void | Select (vtkView *view, vtkSelection *selection, bool extend) |
void | Annotate (vtkView *view, vtkAnnotationLayers *annotations) |
void | Annotate (vtkView *view, vtkAnnotationLayers *annotations, bool extend) |
virtual void | SetSelectable (bool) |
virtual bool | GetSelectable () |
virtual void | SelectableOn () |
virtual void | SelectableOff () |
void | UpdateSelection (vtkSelection *selection) |
void | UpdateSelection (vtkSelection *selection, bool extend) |
void | UpdateAnnotations (vtkAnnotationLayers *annotations) |
void | UpdateAnnotations (vtkAnnotationLayers *annotations, bool extend) |
virtual vtkAlgorithmOutput * | GetInternalAnnotationOutputPort () |
virtual vtkAlgorithmOutput * | GetInternalAnnotationOutputPort (int port) |
virtual vtkAlgorithmOutput * | GetInternalAnnotationOutputPort (int port, int conn) |
virtual vtkAlgorithmOutput * | GetInternalSelectionOutputPort () |
virtual vtkAlgorithmOutput * | GetInternalSelectionOutputPort (int port) |
virtual vtkAlgorithmOutput * | GetInternalSelectionOutputPort (int port, int conn) |
virtual void | SetSelectionType (int) |
virtual int | GetSelectionType () |
virtual void | SetSelectionArrayNames (vtkStringArray *names) |
virtual vtkStringArray * | GetSelectionArrayNames () |
virtual void | SetSelectionArrayName (const char *name) |
virtual const char * | GetSelectionArrayName () |
vtkPassInputTypeAlgorithm * | NewInstance () const |
vtkPolyData * | GetPolyDataOutput () |
vtkStructuredPoints * | GetStructuredPointsOutput () |
vtkImageData * | GetImageDataOutput () |
vtkStructuredGrid * | GetStructuredGridOutput () |
vtkUnstructuredGrid * | GetUnstructuredGridOutput () |
vtkRectilinearGrid * | GetRectilinearGridOutput () |
vtkTable * | GetTableOutput () |
vtkGraph * | GetGraphOutput () |
virtual int | ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
vtkCompositeRepresentation makes is possible to combine multiple representations into one. Only one representation can be active at a give time. vtkCompositeRepresentation provides API to add the representations that form the composite and to pick the active representation.
vtkCompositeRepresentation relies on call AddToView and RemoveFromView on the internal representations whenever it needs to change the active representation. So it is essential that representations handle those methods correctly and don't suffer from uncanny side effects when that's done repeatedly.
Definition at line 28 of file vtkCompositeRepresentation.h.
Definition at line 32 of file vtkCompositeRepresentation.h.
Reimplemented in vtkPVCompositeRepresentation, and vtkPVCompositeOrthographicSliceRepresentation.
vtkDataRepresentation::GetVisibility()
returns false. Reimplemented from vtkPVDataRepresentation.
key
is a unique string used to identify that representation.
key
key
void vtkCompositeRepresentation::SetActiveRepresentation | ( | const char * | key | ) |
Set the active key.
If a valid key is not specified, then none of the representations is treated as active.
const char* vtkCompositeRepresentation::GetActiveRepresentationKey | ( | ) |
Set the active key.
vtkPVDataRepresentation* vtkCompositeRepresentation::GetActiveRepresentation | ( | ) |
We won't need this if vtkPVDataRepresentation correctly respected in the arguments passed to it during ProcessRequest() etc.
void vtkCompositeRepresentation::SetSelectionConnection | ( | vtkAlgorithmOutput * | input | ) |
This is used to pass a selection source output to the mapper in order to display the selection content.
Reimplemented in vtkPVCompositeOrthographicSliceRepresentation, and vtkPVCompositeRepresentation.
vtkStringArray* vtkCompositeRepresentation::GetRepresentationTypes | ( | ) |
Reimplemented in vtkPVCompositeRepresentation.
overrideprotectedvirtual |
Fires UpdateDataEvent.
