virtual void | UpdateFromGlobal (const char *key) |
| Update the current instance to use a previously registered global data object as current output. More...
void | SetOutput (vtkDataObject *output) override |
| Set the data object that is "produced" by this producer. More...
virtual void | SetOutput (vtkDataObject *output, double time) |
| Set the output data object as well as time information for the requests. More...
int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| Process upstream/downstream requests trivially. More...
vtkTrivialProducer * | NewInstance () const |
virtual void | SetWholeExtent (int, int, int, int, int, int) |
virtual void | SetWholeExtent (int[6]) |
virtual int * | GetWholeExtent () |
virtual void | GetWholeExtent (int &, int &, int &, int &, int &, int &) |
virtual void | GetWholeExtent (int[6]) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
| vtkDistributedTrivialProducer () |
| ~vtkDistributedTrivialProducer () override |
| vtkPVTrivialProducer () |
| ~vtkPVTrivialProducer () override |
virtual vtkObjectBase * | NewInstanceInternal () const |
| vtkTrivialProducer () |
| ~vtkTrivialProducer () |
virtual int | FillInputPortInformation (int, vtkInformation *) |
virtual int | FillOutputPortInformation (int, vtkInformation *) |
virtual vtkExecutive * | CreateDefaultExecutive () |
void | ReportReferences (vtkGarbageCollector *) VTK_OVERRIDE |
| vtkAlgorithm () |
| ~vtkAlgorithm () |
virtual void | SetNumberOfInputPorts (int n) |
virtual void | SetNumberOfOutputPorts (int n) |
int | InputPortIndexInRange (int index, const char *action) |
int | OutputPortIndexInRange (int index, const char *action) |
int | GetInputArrayAssociation (int idx, vtkInformationVector **inputVector) |
virtual void | SetNumberOfInputConnections (int port, int n) |
int | GetInputArrayAssociation (int idx, int connection, vtkInformationVector **inputVector) |
int | GetInputArrayAssociation (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkInformation * | GetInputArrayFieldInformation (int idx, vtkInformationVector **inputVector) |
virtual void | SetNthInputConnection (int port, int index, vtkAlgorithmOutput *input) |
void | SetInputDataInternal (int port, vtkDataObject *input) |
void | AddInputDataInternal (int port, vtkDataObject *input) |
virtual void | SetErrorCode (unsigned long) |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
