std::string | GetFilePath (unsigned int rowIndex) const |
| Get the file path associated with the specified row of the meta data. More...
void | SetReader (unsigned int rowIndex, vtkAlgorithm *reader) |
| Set the file reader for the specified row of data. More...
void | ResetReaders () |
| Removes all readers set using SetReader(). More...
bool | UpdateMetaData () |
| Use this method to update the meta data, if needed. More...
virtual void | SetFileName (const char *) |
| Set/Get the filename of the ensemble (.pve extension). More...
virtual char * | GetFileName () |
virtual void | SetCurrentMember (unsigned int) |
| Set/Get the current ensemble member to process. More...
virtual unsigned int | GetCurrentMember () |
unsigned int | GetNumberOfMembers () const |
| Returns the number of ensemble members. More...
virtual unsigned int * | GetCurrentMemberRange () |
virtual void | GetCurrentMemberRange (unsigned int &, unsigned int &) |
virtual void | GetCurrentMemberRange (unsigned int [2]) |
vtkDataObjectAlgorithm * | NewInstance () const |
virtual void | SetOutput (vtkDataObject *d) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
