virtual void | SetArrayName (const char *) |
| Set the name of the array used to compute the range. More...
virtual char * | GetArrayName () |
virtual void | SetFieldType (int) |
| Set/Get the field type of the selection. More...
virtual int | GetFieldType () |
virtual void | SetComponent (int) |
| Set/Get the component used to compute the range. More...
virtual int | GetComponent () |
virtual double * | GetRange () |
| Get the output range. More...
virtual void | GetRange (double &, double &) |
virtual void | GetRange (double [2]) |
vtkTableAlgorithm * | NewInstance () const |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
vtkTable * | GetOutput () |
vtkTable * | GetOutput (int index) |
void | SetInputData (vtkDataObject *obj) |
void | SetInputData (int index, vtkDataObject *obj) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
