vtkHierarchicalFractal Class Reference
A source to test AMR data object. More...
#include <vtkHierarchicalFractal.h>
Inheritance diagram for vtkHierarchicalFractal:
Collaboration diagram for vtkHierarchicalFractal:
typedef vtkCompositeDataSetAlgorithm Superclass
- Public Types inherited from vtkCompositeDataSetAlgorithm
enum  DesiredOutputPrecision
virtual void SetFractalValue (float)
 Essentially the iso surface value. More...
virtual float GetFractalValue ()
virtual void SetMaximumLevel (int)
 Any blocks touching a predefined line will be subdivided to this level. More...
virtual int GetMaximumLevel ()
virtual void SetDimensions (int)
 XYZ dimensions of cells. More...
virtual int GetDimensions ()
virtual void SetGhostLevels (int)
 For testing ghost levels. More...
virtual int GetGhostLevels ()
virtual void GhostLevelsOn ()
virtual void GhostLevelsOff ()
virtual void SetTimeStep (int)
 Dummy time-step. More...
virtual int GetTimeStep ()
virtual intGetTimeStepRange ()
virtual void GetTimeStepRange (int &, int &)
virtual void GetTimeStepRange (int [2])
virtual void SetGenerateRectilinearGrids (int)
 Generate either rectilinear grids either uniform grids. More...
virtual int GetGenerateRectilinearGrids ()
virtual void GenerateRectilinearGridsOn ()
virtual void GenerateRectilinearGridsOff ()
virtual void SetTwoDimensional (int)
 Make a 2D data set to test. More...
virtual int GetTwoDimensional ()
virtual void TwoDimensionalOn ()
virtual void TwoDimensionalOff ()
virtual void SetAsymetric (int)
 Test the case when the blocks do not have the same sizes. More...
virtual int GetAsymetric ()
virtual void SetOverlap (int)
 Test with lower levels overlapping higher levels. More...
virtual int GetOverlap ()
- Public Member Functions inherited from vtkCompositeDataSetAlgorithm
vtkCompositeDataSetAlgorithmNewInstance () const
vtkCompositeDataSetGetOutput ()
vtkCompositeDataSetGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkHierarchicalFractalNew ()
static vtkHierarchicalFractalSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkCompositeDataSetAlgorithm
static vtkCompositeDataSetAlgorithmNew ()
static vtkCompositeDataSetAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkHierarchicalFractal ()
 ~vtkHierarchicalFractal () override
int RequestDataObject (vtkInformation *req, vtkInformationVector **inV, vtkInformationVector *outV) override
int RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
 This is called by the superclass. More...
void Traverse (int &blockId, int level, vtkCompositeDataSet *output, int x0, int x1, int y0, int y1, int z0, int z1, int onFace[6])
int LineTest2 (float x0, float y0, float z0, float x1, float y1, float z1, double bds[6])
int LineTest (float x0, float y0, float z0, float x1, float y1, float z1, double bds[6], int level, int target)
void SetBlockInfo (vtkUniformGrid *grid, int level, int *ext, int onFace[6])
void SetRBlockInfo (vtkRectilinearGrid *grid, int level, int *ext, int onFace[6])
void AddVectorArray (vtkCompositeDataSet *output)
void AddTestArray (vtkCompositeDataSet *output)
void AddFractalArray (vtkCompositeDataSet *output)
void AddBlockIdArray (vtkCompositeDataSet *output)
void AddDepthArray (vtkHierarchicalBoxDataSet *output)
void AddGhostLevelArray (vtkDataSet *grid, int dim[3], int onFace[6])
int MandelbrotTest (double x, double y)
int TwoDTest (double bds[6], int level, int target)
void CellExtentToBounds (int level, int ext[6], double bds[6])
void ExecuteRectilinearMandelbrot (vtkRectilinearGrid *grid, double *ptr)
double EvaluateSet (double p[4])
void GetContinuousIncrements (int extent[6], vtkIdType &incX, vtkIdType &incY, vtkIdType &incZ)
virtual void SetTopLevelSpacing (double, double, double)
virtual void SetTopLevelSpacing (double [3])
virtual doubleGetTopLevelSpacing ()
virtual void GetTopLevelSpacing (double &, double &, double &)
virtual void GetTopLevelSpacing (double [3])
virtual void SetTopLevelOrigin (double, double, double)
virtual void SetTopLevelOrigin (double [3])
virtual doubleGetTopLevelOrigin ()
virtual void GetTopLevelOrigin (double &, double &, double &)
virtual void GetTopLevelOrigin (double [3])
void InternalImageDataCopy (vtkHierarchicalFractal *src)
- Protected Member Functions inherited from vtkCompositeDataSetAlgorithm
 vtkCompositeDataSetAlgorithm ()
 ~vtkCompositeDataSetAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
vtkDataObjectGetInput (int port)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
int StartBlock
int EndBlock
int BlockCount
int TimeStep
int TimeStepRange [2]
int Overlap
int Asymetric
int MaximumLevel
int Dimensions
float FractalValue
int GhostLevels
vtkIntArrayLevels
int TwoDimensional
double TopLevelSpacing [3]
double TopLevelOrigin [3]
int GenerateRectilinearGrids
vtkSmartPointer< HierarchicalFractalOutputUtil > OutputUtil
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkHierarchicalFractal is a collection of uniform grids. All have the same dimensions. Each block has a different origin and spacing. It uses mandelbrot to create cell data. I scale the fractal array to look like a volme fraction. I may also add block id and level as extra cell arrays. If GenerateRectilinearGrids is true then this filter outputs vtkHierarchicalBoxDataSet otherwise it generates a vtkMultiBlockDataSet.
Definition at line 30 of file vtkHierarchicalFractal.h.
Definition at line 36 of file vtkHierarchicalFractal.h.
◆ vtkHierarchicalFractal()
vtkHierarchicalFractal::vtkHierarchicalFractal ( )
◆ ~vtkHierarchicalFractal()
vtkHierarchicalFractal::~vtkHierarchicalFractal ( )
static vtkHierarchicalFractal* vtkHierarchicalFractal::New ( )
virtual const char* vtkHierarchicalFractal::GetClassName ( )
static int vtkHierarchicalFractal::IsTypeOf ( const char *  type)
virtual int vtkHierarchicalFractal::IsA ( const char *  type)
Reimplemented from vtkCompositeDataSetAlgorithm.
static vtkHierarchicalFractal* vtkHierarchicalFractal::SafeDownCast ( vtkObject o)
void vtkHierarchicalFractal::PrintSelf ( ostream &  os,
◆ SetFractalValue()
virtual void vtkHierarchicalFractal::SetFractalValue ( float  )
The fractal array is scaled to map this value to 0.5 for use as a volume fraction.
◆ GetFractalValue()
virtual float vtkHierarchicalFractal::GetFractalValue ( )
◆ SetMaximumLevel()
virtual void vtkHierarchicalFractal::SetMaximumLevel ( int  )
Other blocks are subdivided so that neighboring blocks only differ by one level.
◆ GetMaximumLevel()
virtual int vtkHierarchicalFractal::GetMaximumLevel ( )
◆ SetDimensions()
virtual void vtkHierarchicalFractal::SetDimensions ( int  )
◆ GetDimensions()
virtual int vtkHierarchicalFractal::GetDimensions ( )
◆ SetGhostLevels()
virtual void vtkHierarchicalFractal::SetGhostLevels ( int  )
◆ GetGhostLevels()
virtual int vtkHierarchicalFractal::GetGhostLevels ( )
◆ GhostLevelsOn()
virtual void vtkHierarchicalFractal::GhostLevelsOn ( )
◆ GhostLevelsOff()
virtual void vtkHierarchicalFractal::GhostLevelsOff ( )
◆ SetTimeStep()
virtual void vtkHierarchicalFractal::SetTimeStep ( int  )
Dummy time-step.
◆ GetTimeStep()
virtual int vtkHierarchicalFractal::GetTimeStep ( )
Dummy time-step.
◆ GetTimeStepRange() [1/3]
virtual int* vtkHierarchicalFractal::GetTimeStepRange ( )
Dummy time-step.
◆ GetTimeStepRange() [2/3]
virtual void vtkHierarchicalFractal::GetTimeStepRange ( int ,
int
Dummy time-step.
◆ GetTimeStepRange() [3/3]
virtual void vtkHierarchicalFractal::GetTimeStepRange ( int  [2])
Dummy time-step.
◆ SetGenerateRectilinearGrids()
virtual void vtkHierarchicalFractal::SetGenerateRectilinearGrids ( int  )
Default is false.
◆ GetGenerateRectilinearGrids()
virtual int vtkHierarchicalFractal::GetGenerateRectilinearGrids ( )
Default is false.
◆ GenerateRectilinearGridsOn()
virtual void vtkHierarchicalFractal::GenerateRectilinearGridsOn ( )
Default is false.
◆ GenerateRectilinearGridsOff()
virtual void vtkHierarchicalFractal::GenerateRectilinearGridsOff ( )
Default is false.
◆ SetTwoDimensional()
virtual void vtkHierarchicalFractal::SetTwoDimensional ( int  )
◆ GetTwoDimensional()
virtual int vtkHierarchicalFractal::GetTwoDimensional ( )
◆ TwoDimensionalOn()
virtual void vtkHierarchicalFractal::TwoDimensionalOn ( )
◆ TwoDimensionalOff()
virtual void vtkHierarchicalFractal::TwoDimensionalOff ( )
◆ SetAsymetric()
virtual void vtkHierarchicalFractal::SetAsymetric ( int  )
Adds 2 to the x extent of the far x blocks (level 1).
◆ GetAsymetric()
virtual int vtkHierarchicalFractal::GetAsymetric ( )
◆ SetOverlap()
virtual void vtkHierarchicalFractal::SetOverlap ( int  )
This is what I assume flash is like.
◆ GetOverlap()
virtual int vtkHierarchicalFractal::GetOverlap ( )
◆ RequestDataObject()
int vtkHierarchicalFractal::RequestDataObject ( vtkInformation req,
vtkInformationVector **  inV,
vtkInformationVector outV
overrideprotectedvirtual
◆ RequestInformation()
int vtkHierarchicalFractal::RequestInformation ( vtkInformation request,
vtkInformationVector outputVector
This is the method you should override.
◆ RequestData()
int vtkHierarchicalFractal::RequestData ( vtkInformation request,
◆ Traverse()
void vtkHierarchicalFractal::Traverse ( int blockId,
int  level,
vtkCompositeDataSet output,
int  x0,
int  x1,
int  y0,
int  y1,
int  z0,
int  z1,
int  onFace[6]
◆ LineTest2()
int vtkHierarchicalFractal::LineTest2 ( float  x0,
float  y0,
float  z0,
float  x1,
float  y1,
float  z1,
double  bds[6]
◆ LineTest()
int vtkHierarchicalFractal::LineTest ( float  x0,
float  y0,
float  z0,
float  x1,
float  y1,
float  z1,
double  bds[6],
int  level,
int  target
◆ SetBlockInfo()
void vtkHierarchicalFractal::SetBlockInfo ( vtkUniformGrid grid,
int  level,
int ext,
int  onFace[6]
◆ SetRBlockInfo()
void vtkHierarchicalFractal::SetRBlockInfo ( vtkRectilinearGrid grid,
int  level,
int ext,
int  onFace[6]
◆ AddVectorArray()
void vtkHierarchicalFractal::AddVectorArray ( vtkCompositeDataSet output)
◆ AddTestArray()
void vtkHierarchicalFractal::AddTestArray ( vtkCompositeDataSet output)
◆ AddFractalArray()
void vtkHierarchicalFractal::AddFractalArray ( vtkCompositeDataSet output)
◆ AddBlockIdArray()
void vtkHierarchicalFractal::AddBlockIdArray ( vtkCompositeDataSet output)
◆ AddDepthArray()
void vtkHierarchicalFractal::AddDepthArray ( vtkHierarchicalBoxDataSet output)
◆ AddGhostLevelArray()
void vtkHierarchicalFractal::AddGhostLevelArray ( vtkDataSet grid,
int  dim[3],
int  onFace[6]
◆ MandelbrotTest()
int vtkHierarchicalFractal::MandelbrotTest ( double  x,
double  y
◆ TwoDTest()
int vtkHierarchicalFractal::TwoDTest ( double  bds[6],
int  level,
int  target
◆ CellExtentToBounds()
void vtkHierarchicalFractal::CellExtentToBounds ( int  level,
int  ext[6],
double  bds[6]
◆ ExecuteRectilinearMandelbrot()
void vtkHierarchicalFractal::ExecuteRectilinearMandelbrot ( vtkRectilinearGrid grid,
double ptr
◆ EvaluateSet()
double vtkHierarchicalFractal::EvaluateSet ( double  p[4])
◆ GetContinuousIncrements()
void vtkHierarchicalFractal::GetContinuousIncrements ( int  extent[6],
vtkIdType incX,
vtkIdType incY,
vtkIdType incZ
◆ SetTopLevelSpacing() [1/2]
virtual void vtkHierarchicalFractal::SetTopLevelSpacing ( double  ,
double  ,
double
protectedvirtual
◆ SetTopLevelSpacing() [2/2]
virtual void vtkHierarchicalFractal::SetTopLevelSpacing ( double  [3])
protectedvirtual
◆ GetTopLevelSpacing() [1/3]
virtual double* vtkHierarchicalFractal::GetTopLevelSpacing ( )
protectedvirtual
◆ GetTopLevelSpacing() [2/3]
virtual void vtkHierarchicalFractal::GetTopLevelSpacing ( double ,
double ,
double
protectedvirtual
◆ GetTopLevelSpacing() [3/3]
virtual void vtkHierarchicalFractal::GetTopLevelSpacing ( double  [3])
protectedvirtual
◆ SetTopLevelOrigin() [1/2]
virtual void vtkHierarchicalFractal::SetTopLevelOrigin ( double  ,
double  ,
double
protectedvirtual
◆ SetTopLevelOrigin() [2/2]
virtual void vtkHierarchicalFractal::SetTopLevelOrigin ( double  [3])
protectedvirtual
◆ GetTopLevelOrigin() [1/3]
virtual double* vtkHierarchicalFractal::GetTopLevelOrigin ( )
protectedvirtual
◆ GetTopLevelOrigin() [2/3]
virtual void vtkHierarchicalFractal::GetTopLevelOrigin ( double ,
double ,
double
protectedvirtual
◆ GetTopLevelOrigin() [3/3]
virtual void vtkHierarchicalFractal::GetTopLevelOrigin ( double  [3])
protectedvirtual
◆ InternalImageDataCopy()
void vtkHierarchicalFractal::InternalImageDataCopy ( vtkHierarchicalFractal src)
◆ StartBlock
int vtkHierarchicalFractal::StartBlock
Definition at line 126 of file vtkHierarchicalFractal.h.
◆ EndBlock
int vtkHierarchicalFractal::EndBlock
Definition at line 127 of file vtkHierarchicalFractal.h.
◆ BlockCount
int vtkHierarchicalFractal::BlockCount
Definition at line 128 of file vtkHierarchicalFractal.h.
◆ TimeStep
int vtkHierarchicalFractal::TimeStep
Definition at line 129 of file vtkHierarchicalFractal.h.
◆ TimeStepRange
int vtkHierarchicalFractal::TimeStepRange[2]
Definition at line 130 of file vtkHierarchicalFractal.h.
◆ Overlap
int vtkHierarchicalFractal::Overlap
Definition at line 188 of file vtkHierarchicalFractal.h.
◆ Asymetric
int vtkHierarchicalFractal::Asymetric
Definition at line 189 of file vtkHierarchicalFractal.h.
◆ MaximumLevel
int vtkHierarchicalFractal::MaximumLevel
Definition at line 190 of file vtkHierarchicalFractal.h.
◆ Dimensions
int vtkHierarchicalFractal::Dimensions
Definition at line 191 of file vtkHierarchicalFractal.h.
◆ FractalValue
float vtkHierarchicalFractal::FractalValue
Definition at line 192 of file vtkHierarchicalFractal.h.
◆ GhostLevels
int vtkHierarchicalFractal::GhostLevels
Definition at line 193 of file vtkHierarchicalFractal.h.
◆ Levels
vtkIntArray* vtkHierarchicalFractal::Levels
Definition at line 194 of file vtkHierarchicalFractal.h.
◆ TwoDimensional
int vtkHierarchicalFractal::TwoDimensional
Definition at line 195 of file vtkHierarchicalFractal.h.
◆ TopLevelSpacing
double vtkHierarchicalFractal::TopLevelSpacing[3]
Definition at line 198 of file vtkHierarchicalFractal.h.
◆ TopLevelOrigin
double vtkHierarchicalFractal::TopLevelOrigin[3]
Definition at line 199 of file vtkHierarchicalFractal.h.
int vtkHierarchicalFractal::GenerateRectilinearGrids
Definition at line 201 of file vtkHierarchicalFractal.h.
◆ OutputUtil
vtkSmartPointer<HierarchicalFractalOutputUtil> vtkHierarchicalFractal::OutputUtil
Definition at line 204 of file vtkHierarchicalFractal.h.
