virtual void | SetReadAsImageStack (bool) |
virtual bool | GetReadAsImageStack () |
virtual void | ReadAsImageStackOn () |
virtual void | ReadAsImageStackOff () |
int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| Overridden to directly call the internal reader after passing it the correct filenames when ReadAsImageStack is true. More...
virtual int | CanReadFile (const char *filename) |
| CanReadFile is forwarded to the internal reader if it supports it. More...
virtual void | AddFileName (const char *fname) |
| Adds names of files to be read. More...
virtual void | RemoveAllFileNames () |
| Remove all file names. More...
virtual unsigned int | GetNumberOfFileNames () |
| Returns the number of file names added by AddFileName. More...
virtual const char * | GetFileName (unsigned int idx) |
| Returns the name of a file with index idx. More...
const char * | GetCurrentFileName () |
virtual int | GetUseMetaFile () |
| If true, then use the meta file. More...
virtual void | SetUseMetaFile (int) |
virtual void | UseMetaFileOn () |
virtual void | UseMetaFileOff () |
virtual bool | GetIgnoreReaderTime () |
| If true, then treat file series like it does not contain any time step values. More...
virtual void | SetIgnoreReaderTime (bool) |
virtual void | IgnoreReaderTimeOn () |
virtual void | IgnoreReaderTimeOff () |
| vtkMetaReader () |
| ~vtkMetaReader () override |
vtkMTimeType | GetMTime () override |
| Return the MTime when also considering the internal reader. More...
virtual void | SetReader (vtkAlgorithm *) |
| Set/get the internal reader. More...
virtual vtkAlgorithm * | GetReader () |
void | SetMetaFileName (const char *name) |
| Get/set the filename for the meta-file. More...
char * | GetMetaFileName () |
virtual vtkIdType * | GetFileIndexRange () |
| Returns the available range of file indexes. More...
virtual void | GetFileIndexRange (vtkIdType &, vtkIdType &) |
virtual void | GetFileIndexRange (vtkIdType [2]) |
vtkIdType | GetFileIndex () |
| Get/set the index of the file to read. More...
void | SetFileIndex (vtkIdType i) |
virtual void | SetFileNameMethod (const char *) |
| Name of the method used to set the file name of the internal reader. More...
virtual char * | GetFileNameMethod () |
vtkDataObjectAlgorithm * | NewInstance () const |
virtual void | SetOutput (vtkDataObject *d) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
