void | SelectMaterialArray (const char *name) |
| Material sellection. More...
void | UnselectMaterialArray (const char *name) |
| remove a single array More...
void | UnselectAllMaterialArrays () |
| remove all arrays More...
void | SetMaterialArrayStatus (const char *name, int status) |
| Enable/disable processing on an array. More...
int | GetNumberOfMaterialArrays () |
| Query the number of available arrays. More...
const char * | GetMaterialArrayName (int index) |
| Get the name of a specific array. More...
void | SelectMassArray (const char *name) |
| Mass sellection. More...
void | UnselectMassArray (const char *name) |
void | UnselectAllMassArrays () |
void | SetMassArrayStatus (const char *name, int status) |
int | GetNumberOfMassArrays () |
const char * | GetMassArrayName (int index) |
void | SelectVolumeWtdAvgArray (const char *name) |
| Volume weighted average attribute sellection. More...
void | UnselectVolumeWtdAvgArray (const char *name) |
void | UnselectAllVolumeWtdAvgArrays () |
void | SetVolumeWtdAvgArrayStatus (const char *name, int status) |
int | GetNumberOfVolumeWtdAvgArrays () |
const char * | GetVolumeWtdAvgArrayName (int index) |
void | SelectMassWtdAvgArray (const char *name) |
| Mass weighted average attribute sellection. More...
void | UnselectMassWtdAvgArray (const char *name) |
void | UnselectAllMassWtdAvgArrays () |
void | SetMassWtdAvgArrayStatus (const char *name, int status) |
int | GetNumberOfMassWtdAvgArrays () |
const char * | GetMassWtdAvgArrayName (int index) |
void | SelectSummationArray (const char *name) |
| Summation attribute sellection. More...
void | UnselectSummationArray (const char *name) |
void | UnselectAllSummationArrays () |
void | SetSummationArrayStatus (const char *name, int status) |
int | GetNumberOfSummationArrays () |
const char * | GetSummationArrayName (int index) |
vtkMTimeType | GetMTime () override |
| Return the mtime also considering the locator and clip function. More...
int | GetMaterialArrayStatus (const char *name) |
| Get enable. More...
int | GetMaterialArrayStatus (int index) |
| Get enable. More...
int | GetMassArrayStatus (const char *name) |
| Get enable. More...
int | GetMassArrayStatus (int index) |
| Get enable. More...
int | GetVolumeWtdAvgArrayStatus (const char *name) |
| Get enable. More...
int | GetVolumeWtdAvgArrayStatus (int index) |
| Get enable. More...
int | GetMassWtdAvgArrayStatus (const char *name) |
| Get enable. More...
int | GetMassWtdAvgArrayStatus (int index) |
| Get enable. More...
int | GetSummationArrayStatus (const char *name) |
| Get enable. More...
int | GetSummationArrayStatus (int index) |
| Get enable. More...
void | SetMaterialFractionThreshold (double fraction) |
| Volume Fraction. More...
virtual double | GetMaterialFractionThreshold () |
virtual void | SetComputeOBB (bool) |
| OBB. More...
virtual bool | GetComputeOBB () |
| OBB. More...
void | SetUpperLoadingBound (int nPolys) |
| Loading. More...
virtual int | GetUpperLoadingBound () |
| Loading. More...
virtual void | SetOutputBaseName (const char *) |
| Output file. More...
virtual char * | GetOutputBaseName () |
virtual void | SetWriteGeometryOutput (bool) |
| If true, save the results of the filter in a text file. More...
virtual bool | GetWriteGeometryOutput () |
virtual void | SetWriteStatisticsOutput (bool) |
virtual bool | GetWriteStatisticsOutput () |
virtual void | SetBlockGhostLevel (unsigned char) |
| Variable used to specify the number of ghost level is available in each block. More...
virtual unsigned char | GetBlockGhostLevel () |
void | SetClipFunction (vtkImplicitFunction *clipFunction) |
| Set the clip function which can be a plane or a sphere. More...
virtual vtkImplicitFunction * | GetClipFunction () |
virtual void | SetInvertVolumeFraction (int) |
| Invert the volume fraction to extract the negative space. More...
virtual int | GetInvertVolumeFraction () |
vtkMultiBlockDataSetAlgorithm * | NewInstance () const |
vtkMultiBlockDataSet * | GetOutput () |
vtkMultiBlockDataSet * | GetOutput (int) |
virtual int | ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
