Call a class member method in response to a VTK event. More...
#include <vtkMemberFunctionCommand.h>
typedef vtkCommand | Superclass |
const char * | GetClassNameInternal () const override |
void | SetCallback (ClassT &object, void(ClassT::*method2)(vtkObject *, unsigned long, void *)) |
void | Execute (vtkObject *caller, unsigned long event, void *calldata) override |
void | Reset () |
void | SetCallback (ClassT &object, void(ClassT::*method)()) |
Set which class instance and member function will be called when a VTK event is received. More... | |
vtkBaseTypeMacro (vtkCommand, vtkObjectBase) | |
void | UnRegister () |
virtual void | UnRegister (vtkObjectBase *) |
void | SetAbortFlag (int f) |
int | GetAbortFlag () |
void | AbortFlagOn () |
void | AbortFlagOff () |
void | SetPassiveObserver (int f) |
int | GetPassiveObserver () |
void | PassiveObserverOn () |
void | PassiveObserverOff () |
vtkCommand () | |
virtual | ~vtkCommand () |
vtkCommand (const vtkCommand &c) | |
void | operator= (const vtkCommand &) |
virtual vtkTypeBool | IsA (const char *name) |
static ThisT * | SafeDownCast (vtkObjectBase *o) |
static ThisT * | New () |
static const char * | GetStringFromEventId (unsigned long event) |
static unsigned long | GetEventIdFromString (const char *event) |
vtkEventDeclarationMacro(EventIds) protected int | PassiveObserver |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
virtual void | RegisterInternal (vtkObjectBase *, vtkTypeBool check) |
virtual void | UnRegisterInternal (vtkObjectBase *, vtkTypeBool check) |
vtkMemberFunctionCommand is a vtkCommand-derivative that will listen for VTK events, calling a class member function when a VTK event is received.
It is generally more useful than vtkCallbackCommand, which can only call non-member functions in response to a VTK event.
Usage: create an instance of vtkMemberFunctionCommand, specialized for the class that will receive events. Use the SetCallback() method to pass the instance and member function that will be called when an event is received. Use vtkObject::AddObserver() to control which VTK events the vtkMemberFunctionCommand object will receive.
Usage:
vtkObject* subject = ... foo* observer = ... vtkMemberFunctionCommand<foo>* adapter = vtkMemberFunctionCommand<foo>::New(); adapter->SetCallback(observer, &foo::bar); subject->AddObserver(vtkCommand::AnyEvent, adapter);
Alternative Usage
vtkCommand* command = vtkMakeMemberFunctionCommand(*observer, &foo::Callback); subject->AddObserver(vtkCommand::AnyEvent, command);
There are two types of callback methods that could be defined.
Definition at line 49 of file vtkMemberFunctionCommand.h.
typedef vtkCommand vtkMemberFunctionCommand< ClassT >::Superclass |
Definition at line 54 of file vtkMemberFunctionCommand.h.
inlineoverride |
Definition at line 56 of file vtkMemberFunctionCommand.h.
inlinestatic |
Definition at line 58 of file vtkMemberFunctionCommand.h.
inlinestatic |
Definition at line 60 of file vtkMemberFunctionCommand.h.
inlineoverridevirtual |
Definition at line 62 of file vtkMemberFunctionCommand.h.
Definition at line 72 of file vtkMemberFunctionCommand.h.
Definition at line 79 of file vtkMemberFunctionCommand.h.
Implements vtkCommand.
Definition at line 85 of file vtkMemberFunctionCommand.h.
Definition at line 96 of file vtkMemberFunctionCommand.h.
