An interface to access VTK Importers from ParaView server manager. More...
#include <vtkMetaImporter.h>
void | UpdateInformation () |
Imports the scene and populates scene hierarchy as well as scene description. More... | |
virtual int | GetAssemblyTag () |
Whenever the assembly is changed, this tag gets changed. More... | |
void | SetFileName (const char *filename) |
Set/Get the file name. More... | |
const char * | GetFileName () |
vtkDataAssembly * | GetAssembly () |
The hierarchy of actors in the renderer is encoded in a vtkDataAssembly. More... | |
virtual void | SetActiveAssembly (const char *) |
Get/Set the name of the assembly to use for mapping block visibilities, colors and opacities. More... | |
virtual char * | GetActiveAssembly () |
void | AddNodeSelector (const char *selector) |
Update list of selectors that determine the selected nodes. More... | |
void | RemoveAllNodeSelectors () |
virtual void | Modified () |
static vtkMetaImporter * | New () |
static vtkMetaImporter * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkMetaImporter () | |
~vtkMetaImporter () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
int | AssemblyTag = 0 |
char * | ActiveAssembly = nullptr |
std::string | FileName |
bool | Debug |
vtkTimeStamp | MTime |
using | PayloadType = vtkAOSDataArrayTemplate< vtkTypeUInt8 > |
The scene description i.e, material, texture, transformation matrices for actors, cameras and lights is serialized to JSON and transformed into CBOR (Consise Binary Object Representation) stored in a vtkTypeUInt8Array for easier transmission across the network. More... | |
vtkVariant | GetSerializedSceneDescription () |
This class creates the correct vtkImporter subclass based on the file extension. It provides common metadata like scene hierarchy and a description of the scene. The metadata is accessible after calling UpdatePipelineInformation.
Definition at line 28 of file vtkMetaImporter.h.
typedef vtkObject vtkMetaImporter::Superclass |
Definition at line 32 of file vtkMetaImporter.h.
using vtkMetaImporter::PayloadType = vtkAOSDataArrayTemplate<vtkTypeUInt8> |
Definition at line 55 of file vtkMetaImporter.h.
void vtkMetaImporter::SetFileName | ( | const char * | filename | ) |
const char* vtkMetaImporter::GetFileName | ( | ) |
void vtkMetaImporter::UpdateInformation | ( | ) |
vtkVariant vtkMetaImporter::GetSerializedSceneDescription | ( | ) |
vtkDataAssembly* vtkMetaImporter::GetAssembly | ( | ) |
The default is Hierarchy.
Note, users should not assume that this is monotonically increasing but instead simply rely on its value to determine if the assembly may have changed since last time.
It is set to 0 whenever there's no valid assembly available.
void vtkMetaImporter::AddNodeSelector | ( | const char * | selector | ) |
void vtkMetaImporter::RemoveAllNodeSelectors | ( | ) |
Definition at line 98 of file vtkMetaImporter.h.
Definition at line 99 of file vtkMetaImporter.h.
Definition at line 100 of file vtkMetaImporter.h.
