collection of assorted helper routines dealing with communication. More...
#include <vtkMultiProcessControllerHelper.h>
virtual void | Modified () |
static vtkMultiProcessControllerHelper * | New () |
static vtkMultiProcessControllerHelper * | SafeDownCast (vtkObject *o) |
static int | ReduceToAll (vtkMultiProcessController *controller, vtkMultiProcessStream &data, void(*operation)(vtkMultiProcessStream &A, vtkMultiProcessStream &B), int tag) |
Reduce the stream to all processes calling the (*operation) for reduction. More... | |
static vtkDataObject * | MergePieces (vtkDataObject **pieces, unsigned int num_pieces) |
Utility method to merge pieces received from several processes. More... | |
static bool | MergePieces (std::vector< vtkSmartPointer< vtkDataObject >> &pieces, vtkDataObject *result) |
Overload where the merged pieces are combined into result. More... | |
static vtkObject * | New () |
vtkMultiProcessControllerHelper () | |
~vtkMultiProcessControllerHelper () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
bool | Debug |
vtkTimeStamp | MTime |
vtkMultiProcessControllerHelper is collection of assorted helper routines dealing with communication.
Definition at line 25 of file vtkMultiProcessControllerHelper.h.
Definition at line 29 of file vtkMultiProcessControllerHelper.h.
The operation is assumed to be commutative.
It does not handle all data types, and hence not meant for non-paraview specific use. Returns a new instance of data object containing the merged result on success, else returns nullptr. The caller is expected to release the memory from the returned data-object.
