bool | Paint (vtkContext2D *painter) override |
| Paint the texture into a rectangle defined by the bounds. More...
vtkAxis * | GetAxis () |
| Return the Axis on which that ContextItem is based. More...
void | SetActiveSize (int size) |
| The active size define the number of pixel that are going to be used for the slider handle. More...
void | SetEdgeMargin (int margin) |
| The margin used on the side of the Axis. More...
int | GetActiveSliceIndex () |
| Returns the active slice index. More...
bool | Hit (const vtkContextMouseEvent &mouse) override |
| Return true if the supplied x, y coordinate is inside the item. More...
bool | MouseButtonPressEvent (const vtkContextMouseEvent &mouse) override |
| Mouse button down event Return true if the item holds the event, false if the event can be propagated to other items. More...
bool | MouseButtonReleaseEvent (const vtkContextMouseEvent &mouse) override |
| Mouse button release event. More...
bool | MouseDoubleClickEvent (const vtkContextMouseEvent &mouse) override |
| Mouse button double click event. More...
bool | MouseMoveEvent (const vtkContextMouseEvent &mouse) override |
| Mouse move event. More...
const double * | GetVisibleSlices (int &nbSlices) const |
| Get access to the data model. More...
const double * | GetSlices (int &nbSlices) const |
| Returns access to slices. More...
void | SetSlices (double *values, bool *visibility, int numberOfSlices) |
| Allow user to programmatically update the data model. More...
double | GetSliceValue (int sliceIndex) |
| Return the slice position for a given index. More...
int | GetNumberOfSlices () |
| Return the number of slices. More...
vtkContextItem * | NewInstance () const |
virtual double | GetOpacity () |
virtual void | SetOpacity (double) |
vtkAbstractContextItem * | NewInstance () const |
virtual void | Update () |
virtual bool | PaintChildren (vtkContext2D *painter) |
virtual void | ReleaseGraphicsResources () |
unsigned int | AddItem (vtkAbstractContextItem *item) |
bool | RemoveItem (vtkAbstractContextItem *item) |
bool | RemoveItem (unsigned int index) |
vtkAbstractContextItem * | GetItem (unsigned int index) |
unsigned int | GetItemIndex (vtkAbstractContextItem *item) |
unsigned int | GetNumberOfItems () |
void | ClearItems () |
unsigned int | Raise (unsigned int index) |
unsigned int | Lower (unsigned int index) |
virtual vtkAbstractContextItem * | GetPickedItem (const vtkContextMouseEvent &mouse) |
virtual bool | MouseEnterEvent (const vtkContextMouseEvent &mouse) |
virtual bool | MouseLeaveEvent (const vtkContextMouseEvent &mouse) |
virtual bool | MouseWheelEvent (const vtkContextMouseEvent &mouse, int delta) |
virtual bool | KeyPressEvent (const vtkContextKeyEvent &key) |
virtual bool | KeyReleaseEvent (const vtkContextKeyEvent &key) |
virtual void | SetScene (vtkContextScene *scene) |
virtual void | SetParent (vtkAbstractContextItem *parent) |
virtual vtkVector2f | MapToParent (const vtkVector2f &point) |
virtual vtkVector2f | MapFromParent (const vtkVector2f &point) |
virtual vtkVector2f | MapToScene (const vtkVector2f &point) |
virtual vtkVector2f | MapFromScene (const vtkVector2f &point) |
virtual unsigned int | StackAbove (unsigned int index, unsigned int under) |
virtual unsigned int | StackUnder (unsigned int child, unsigned int above) |
vtkContextScene * | GetScene () |
vtkAbstractContextItem * | GetParent () |
virtual bool | GetVisible () |
virtual void | SetVisible (bool) |
virtual bool | GetInteractive () |
virtual void | SetInteractive (bool) |
virtual void | Modified () |
