void | SetImageResolution (int img_width, int img_height) |
| Communicates the next expected image resolution. More...
virtual void | SetQuality (unsigned int) |
| Set the quality measure. More...
virtual unsigned int | GetQuality () |
virtual int | Compress () |
| Call this method to compress the input and generate the compressed data. More...
virtual int | Decompress () |
| Decompresses and geenartes the decompressed data as output. More...
virtual void | SaveConfiguration (vtkMultiProcessStream *stream) |
virtual bool | RestoreConfiguration (vtkMultiProcessStream *stream) |
virtual const char * | SaveConfiguration () |
virtual const char * | RestoreConfiguration (const char *stream) |
void | SetInput (vtkUnsignedCharArray *input) |
| Get/Set the input to this compressor. More...
virtual vtkUnsignedCharArray * | GetInput () |
virtual vtkUnsignedCharArray * | GetOutput () |
| Get/Set the output of the compressor. More...
void | SetOutput (vtkUnsignedCharArray *) |
virtual void | SetLossLessMode (int) |
| When set the implementation must use loss-less compression, otherwise implemnetation should user provided settings. More...
virtual int | GetLossLessMode () |
virtual void | Modified () |
