void | PrintSelf (ostream &os, vtkIndent indent) |
virtual void | SetRunSubHaloFinder (bool) |
| Turns on/off the subhalo finder part of the algorithm Default: Off. More...
virtual bool | GetRunSubHaloFinder () |
virtual void | RunSubHaloFinderOn () |
virtual void | RunSubHaloFinderOff () |
virtual void | SetRL (double) |
| Gets/Sets RL, the physical coordinate box size Default: 256.0. More...
virtual double | GetRL () |
virtual void | SetDistanceConvertFactor (double) |
| Gets/Sets the distance conversion factor. More...
virtual double | GetDistanceConvertFactor () |
virtual void | SetMassConvertFactor (double) |
| Gets/Sets the mass conversion factor. More...
virtual double | GetMassConvertFactor () |
virtual void | SetDeadSize (double) |
| Gets/Sets the size of the ghost particle region around each process's particles to exchange when creating ghost particles. More...
virtual double | GetDeadSize () |
virtual void | SetParticleMass (float) |
| Gets/Sets the particle mass. More...
virtual float | GetParticleMass () |
virtual void | SetBB (double) |
| Gets/Sets distance threshold for particles to be considered in the same halo. More...
virtual double | GetBB () |
virtual void | SetAlphaFactor (double) |
| Gets/Sets alpha factor. More...
virtual double | GetAlphaFactor () |
virtual void | SetBetaFactor (double) |
| Gets/Sets beta factor. More...
virtual double | GetBetaFactor () |
virtual void | SetNP (int) |
| Gets/Sets NP Default: 1024. More...
virtual int | GetNP () |
virtual void | SetNMin (int) |
| Gets/Sets the minimum number of close neighbors for a halo candidate to include a particle. More...
virtual int | GetNMin () |
virtual void | SetPMin (int) |
| Gets/Sets the minimum number of particles required for a halo candidate to be considered a halo and output Default: 10000. More...
virtual int | GetPMin () |
virtual void | SetMinFOFSubhaloSize (long) |
| Gets/Sets the minimum halo size to run the subhalo finder on. More...
virtual long | GetMinFOFSubhaloSize () |
virtual void | SetMinCandidateSize (int) |
| Gets/Sets the minimum size of a subhalo candidate Default: 200. More...
virtual int | GetMinCandidateSize () |
virtual void | SetNumSPHNeighbors (int) |
| Gets/Sets NumSPHNeighbors Default: 64. More...
virtual int | GetNumSPHNeighbors () |
virtual void | SetNumNeighbors (int) |
| Gets/Sets the number of neighbors that are examined by the subhalo finder to determine local clumps near the each particle Default: 20. More...
virtual int | GetNumNeighbors () |
virtual void | SetCenterFindingMode (int) |
| Gets/Sets the center finding method used by the halo finder once halos are identified. More...
virtual int | GetCenterFindingMode () |
virtual void | SetSmoothingLength (double) |
| Gets/Sets the smoothing length used by the center finders Default: 0.0. More...
virtual double | GetSmoothingLength () |
virtual void | SetOmegaDM (double) |
| Gets/Sets the OmegaDM parameter of the simulation. More...
virtual double | GetOmegaDM () |
virtual void | SetOmegaNU (double) |
| Gets/Sets the OmegaNU parameter of the simulation. More...
virtual double | GetOmegaNU () |
virtual void | SetDeut (double) |
| Gets/Sets the Deut parameter of the simulation. More...
virtual double | GetDeut () |
virtual void | SetHubble (double) |
| Gets/Sets the Hubble parameter of the simulation. More...
virtual double | GetHubble () |
virtual void | SetRedShift (double) |
| Gets/Sets the current redshift. More...
virtual double | GetRedShift () |
vtkUnstructuredGridAlgorithm * | NewInstance () const |
vtkUnstructuredGrid * | GetUnstructuredGridInput (int port) |
vtkUnstructuredGrid * | GetOutput () |
vtkUnstructuredGrid * | GetOutput (int) |
virtual void | SetOutput (vtkDataObject *d) |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
