void | PrintSelf (ostream &os, vtkIndent indent) |
virtual void | SetFileName (const char *) |
| Specify the name of the cosmology particle binary file to read. More...
virtual char * | GetFileName () |
virtual void | SetRL (float) |
| Specify the physical box dimensions size (rL) (default 100.0) More...
virtual float | GetRL () |
virtual void | SetOverlap (float) |
| Specify the ghost cell spacing in Mpc (in rL units) (edge boundary of processor box) (default 5) More...
virtual float | GetOverlap () |
virtual void | SetReadMode (int) |
| Set the read mode (0 = one-to-one, 1 = default, round-robin) More...
virtual int | GetReadMode () |
virtual void | SetCosmoFormat (int) |
| Set whether to byte-swap or not the data. More...
virtual int | GetCosmoFormat () |
virtual vtkMultiProcessController * | GetController () |
| Set the communicator object for interprocess communication. More...
virtual void | SetController (vtkMultiProcessController *) |
vtkUnstructuredGridAlgorithm * | NewInstance () const |
vtkUnstructuredGrid * | GetUnstructuredGridInput (int port) |
vtkUnstructuredGrid * | GetOutput () |
vtkUnstructuredGrid * | GetOutput (int) |
virtual void | SetOutput (vtkDataObject *d) |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
