| vtkPEnSightGoldReader () |
| ~vtkPEnSightGoldReader () override |
int | ReadGeometryFile (const char *fileName, int timeStep, vtkMultiBlockDataSet *output) override |
| Read the geometry file. More...
int | ReadMeasuredGeometryFile (const char *fileName, int timeStep, vtkMultiBlockDataSet *output) override |
| Read the measured geometry file. More...
int | ReadScalarsPerNode (const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output, int measured=0, int numberOfComponents=1, int component=0) override |
| Read scalars per node for this dataset. More...
int | ReadVectorsPerNode (const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output, int measured=0) override |
| Read vectors per node for this dataset. More...
int | ReadTensorsPerNode (const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output) override |
| Read tensors per node for this dataset. More...
int | ReadScalarsPerElement (const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output, int numberOfComponents=1, int component=0) override |
| Read scalars per element for this dataset. More...
int | ReadVectorsPerElement (const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output) override |
| Read vectors per element for this dataset. More...
int | ReadTensorsPerElement (const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output) override |
| Read tensors per element for this dataset. More...
int | CreateUnstructuredGridOutput (int partId, char line[256], const char *name, vtkMultiBlockDataSet *output) override |
| Read an unstructured part (partId) from the geometry file and create a vtkUnstructuredGrid output. More...
int | CreateStructuredGridOutput (int partId, char line[256], const char *name, vtkMultiBlockDataSet *output) override |
| Read a structured part from the geometry file and create a vtkStructuredGrid output. More...
int | CreateRectilinearGridOutput (int partId, char line[256], const char *name, vtkMultiBlockDataSet *output) |
| Read a structured part from the geometry file and create a vtkRectilinearGrid output. More...
int | CreateImageDataOutput (int partId, char line[256], const char *name, vtkMultiBlockDataSet *output) |
| Read a structured part from the geometry file and create a vtkImageData output. More...
int | ReadOrSkipCoordinates (vtkPoints *points, long offset, int partId, int *lineRead, char *line, bool skip) |
| Read Coordinates, or just skip the part in the file. More...
int | InjectCoordinatesAtEnd (vtkUnstructuredGrid *output, long coordinatesOffset, int partId) |
| Internal method to inject coordinates at the end of a part read for unstructured data. More...
int | CheckForUndefOrPartial (const char *line) |
| Skip next line in file if the 'undef' or 'partial' keyword was specified after a sectional keyword. More...
| vtkPEnSightReader () |
| ~vtkPEnSightReader () override |
int | RequestInformation (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
int | RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
int | ReadVariableFiles (vtkMultiBlockDataSet *output) |
| Read the variable files. More...
virtual int | CreateUnstructuredGridOutput (int partId, char line[80], const char *name, vtkMultiBlockDataSet *output)=0 |
virtual int | CreateStructuredGridOutput (int partId, char line[80], const char *name, vtkMultiBlockDataSet *output)=0 |
| Read a structured part from the geometry file and create a vtkStructuredGridOutput. More...
void | AddVariableFileName (const char *fileName1, const char *fileName2=nullptr) |
| Add another file name to the list for a particular variable type. More...
void | AddVariableDescription (const char *description) |
| Add another description to the list for a particular variable type. More...
void | AddVariableType () |
| Record the variable type for the variable line just read. More...
int | GetElementType (const char *line) |
| Determine the element type from a line read a file. More...
int | GetSectionType (const char *line) |
| Determine the section type from a line read a file. More...
void | ReplaceWildcards (char *filename, int num) |
| Replace the *'s in the filename with the given filename number. More...
void | RemoveLeadingBlanks (char *line) |
| Remove leading blank spaces from a string. More...
vtkPEnSightReaderCellIds * | GetCellIds (int index, int cellType) |
| Get the list for the given output index and cell type. More...
vtkPEnSightReaderCellIds * | GetPointIds (int index) |
| Distributed Read Only. More...
void | AddToBlock (vtkMultiBlockDataSet *output, unsigned int blockNo, vtkDataSet *dataset) |
| Convenience method use to convert the readers from VTK 5 multiblock API to the current composite data infrastructure. More...
vtkDataSet * | GetDataSetFromBlock (vtkMultiBlockDataSet *output, unsigned int blockNo) |
void | SetBlockName (vtkMultiBlockDataSet *output, unsigned int blockNo, const char *name) |
| Set the name of a block. More...
void | MapToGlobalIds (const vtkIdType *inputIds, vtkIdType numPoints, int partId, vtkIdType *globalIds) |
| Convenience method to map the point ids from current rank to global ids. More...
void | PrepareStructuredDimensionsForDistribution (int partId, int *oldDimensions, int *newDimensions, int *splitDimension, int *splitDimensionBeginIndex, int ghostLevel, vtkUnsignedCharArray *pointGhostArray, vtkUnsignedCharArray *cellGhostArray) |
virtual void | SetUseTimeSets (int) |
virtual int | GetUseTimeSets () |
virtual void | UseTimeSetsOn () |
virtual void | UseTimeSetsOff () |
virtual void | SetUseFileSets (int) |
virtual int | GetUseFileSets () |
virtual void | UseFileSetsOn () |
virtual void | UseFileSetsOff () |
int | CheckOutputConsistency () |
virtual void | SetMeasuredFileName (const char *) |
| Set the Measured file name. More...
virtual void | SetMatchFileName (const char *) |
| Set the Match file name. More...
int | ReadCaseFile () |
| Read the case file. More...
int | ReadCaseFileGeometry (char *line) |
int | ReadCaseFileVariable (char *line) |
int | ReadCaseFileTime (char *line) |
int | ReadCaseFileFile (char *line) |
vtkIdType | GetTotalNumberOfCellIds (int index) |
vtkIdType | GetLocalTotalNumberOfCellIds (int index) |
void | InsertNextCellAndId (vtkUnstructuredGrid *, int vtkCellType, vtkIdType numPoints, vtkIdType *points, int partId, int ensightCellType, vtkIdType globalId, vtkIdType numElements, const std::vector< vtkIdType > &faces={}) |
| Merge InsertNextCell & GetId->InsertNextId Take Distributed Read into account. More...
void | InsertVariableComponent (vtkFloatArray *array, int i, int component, float *content, int partId, int ensightCellType, int insertionType) |
| vtkPGenericEnSightReader () |
| ~vtkPGenericEnSightReader () override |
int | GetMultiProcessLocalProcessId () |
| Multi Process cache. More...
int | GetMultiProcessNumberOfProcesses () |
virtual vtkObjectBase * | NewInstanceInternal () const |
| vtkGenericEnSightReader () |
| ~vtkGenericEnSightReader () |
virtual int | FillOutputPortInformation (int port, vtkInformation *info) |
virtual void | ClearForNewCaseFileName () |
int | ReadLine (char result[256]) |
int | ReadBinaryLine (char result[80]) |
int | ReadNextDataLine (char result[256]) |
void | SelectionModified () |
char ** | CreateStringArray (int numStrings) |
void | DestroyStringArray (int numStrings, char **strings) |
void | SetDataArraySelectionSetsFromVariables () |
void | SetDataArraySelectionSetsFromReader () |
void | SetReaderDataArraySelectionSetsFromSelf () |
virtual void | SetTimeSets (vtkDataArrayCollection *) |
int | InsertNewPartId (int partId) |
virtual void | SetGeometryFileName (const char *) |
void | AddComplexVariableDescription (const char *description) |
void | AddVariableType (int variableType) |
void | AddComplexVariableType (int variableType) |
int | ReplaceWildcards (char *fileName, int timeSet, int fileSet) |
void | ReplaceWildcardsHelper (char *fileName, int num) |
| vtkMultiBlockDataSetAlgorithm () |
| ~vtkMultiBlockDataSetAlgorithm () |
virtual vtkExecutive * | CreateDefaultExecutive () |
virtual int | FillInputPortInformation (int port, vtkInformation *info) |
virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
virtual int | RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| vtkAlgorithm () |
| ~vtkAlgorithm () |
virtual void | SetNumberOfInputPorts (int n) |
virtual void | SetNumberOfOutputPorts (int n) |
int | InputPortIndexInRange (int index, const char *action) |
int | OutputPortIndexInRange (int index, const char *action) |
int | GetInputArrayAssociation (int idx, vtkInformationVector **inputVector) |
void | ReportReferences (vtkGarbageCollector *) VTK_OVERRIDE |
virtual void | SetNumberOfInputConnections (int port, int n) |
int | GetInputArrayAssociation (int idx, int connection, vtkInformationVector **inputVector) |
int | GetInputArrayAssociation (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkInformation * | GetInputArrayFieldInformation (int idx, vtkInformationVector **inputVector) |
virtual void | SetNthInputConnection (int port, int index, vtkAlgorithmOutput *input) |
void | SetInputDataInternal (int port, vtkDataObject *input) |
void | AddInputDataInternal (int port, vtkDataObject *input) |
virtual void | SetErrorCode (unsigned long) |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
