int | GetNumberOfPointArrays () |
| Returns the number of arrays in the file, i.e., the number of columns. More...
const char * | GetPointArrayName (int i) |
| Returns the name of the ith array. More...
int | GetPointArrayStatus (const char *name) |
| Returns the status of the array corresponding to the given name. More...
void | SetPointArrayStatus (const char *name, int status) |
| Sets the status of the array corresponding to the given name. More...
vtkIdType | GetRequestedHaloId (vtkIdType i) |
| Gets the ith requested halo id. More...
vtkIdType | GetNumberOfRequestedHaloIds () |
| Gets the number of requested halo ids. More...
void | SetNumberOfRequestedHaloIds (vtkIdType numIds) |
| Sets the number of requested halo ids. More...
void | AddRequestedHaloId (vtkIdType haloId) |
| Adds the given halo id to the list of halo ids to request. More...
void | ClearRequestedHaloIds () |
| Clears the list of requested halo ids. More...
void | SetRequestedHaloId (vtkIdType i, vtkIdType haloId) |
| Sets the ith requested halo id to the given haloId. More...
virtual void | SetXAxisVariableName (const char *) |
| Set/Get the variable name to be used as the x-axis for plotting particles. More...
virtual char * | GetXAxisVariableName () |
virtual void | SetYAxisVariableName (const char *) |
| Set/Get the variable name to be used as the y-axis for plotting particles. More...
virtual char * | GetYAxisVariableName () |
virtual void | SetZAxisVariableName (const char *) |
| Set/Get the variable name to be used as the z-axis for plotting particles. More...
virtual char * | GetZAxisVariableName () |
virtual void | SetFileName (const char *) |
| Specify the name of the cosmology particle binary file to read. More...
virtual char * | GetFileName () |
virtual void | SetGenericIOType (int) |
| Set/Get the underlying IO method the reader will employ, i.e., MPI or POSIX. More...
virtual int | GetGenericIOType () |
virtual void | SetBlockAssignment (int) |
| Set/Get the underlying block-assignment strategy to use, i.e., ROUND_ROBIN, or RCB. More...
virtual int | GetBlockAssignment () |
virtual vtkStringArray * | GetArrayList () |
| Returns the list of arrays used to select the variables to be used for the x,y and z axis. More...
virtual vtkDataArraySelection * | GetPointDataArraySelection () |
| Get the data array selection tables used to configure which data arrays are loaded by the reader. More...
virtual vtkMultiProcessController * | GetController () |
| Set/Get a multiprocess-controller for reading in parallel. More...
virtual void | SetController (vtkMultiProcessController *) |
virtual void | SetHaloIdVariableName (const char *) |
| Gets/Sets the variable name for the halo id of the particle. More...
virtual char * | GetHaloIdVariableName () |
vtkMultiBlockDataSetAlgorithm * | NewInstance () const |
vtkMultiBlockDataSet * | GetOutput () |
vtkMultiBlockDataSet * | GetOutput (int) |
virtual int | ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
