void | PrintSelf (ostream &os, vtkIndent indent) |
virtual vtkMultiProcessController * | GetController () |
| Set the communicator object for interprocess communication. More...
virtual void | SetController (vtkMultiProcessController *) |
virtual void | SetNP (int) |
| Specify the number of seeded particles in one dimension (total = np^3) (default 256) More...
virtual int | GetNP () |
virtual void | SetRL (float) |
| Specify the physical box dimensions size (rL) (default 100.0) More...
virtual float | GetRL () |
virtual void | SetOverlap (float) |
| Specify the ghost cell spacing (in rL units) (edge boundary of processor box) (default 5) More...
virtual float | GetOverlap () |
virtual void | SetPMin (int) |
| Specify the minimum number of particles for a halo (pmin) (default 100) More...
virtual int | GetPMin () |
virtual void | SetBB (float) |
| Specify the linking length (bb) (default .2) More...
virtual float | GetBB () |
virtual void | SetComputeSOD (int) |
| Turn on calculation of SOD halos (default off) More...
virtual int | GetComputeSOD () |
virtual void | SetCenterFindingMethod (int) |
| Specify the FOF center to use in SOD calculations (0 = default, center of mass, 1 = average, 2 = MBP, 3 = MCP) More...
virtual int | GetCenterFindingMethod () |
virtual void | SetRhoC (float) |
| Specify rho_c (critical density) (default 2.77536627e11) More...
virtual float | GetRhoC () |
virtual void | SetSODMass (float) |
| Specify the initial SOD mass (default 1.0e14) More...
virtual float | GetSODMass () |
virtual void | SetMinRadiusFactor (float) |
| Specify the minimum radius factor (default 0.5) More...
virtual float | GetMinRadiusFactor () |
virtual void | SetMaxRadiusFactor (float) |
| Specify the maximum radius factor (default 2.0) More...
virtual float | GetMaxRadiusFactor () |
virtual void | SetSODBins (int) |
| Specify the number of bins for SOD finding (default 20) More...
virtual int | GetSODBins () |
virtual void | SetMinFOFSize (int) |
| Specify the minimum FOF size for an SOD halo (default 1000) More...
virtual int | GetMinFOFSize () |
virtual void | SetMinFOFMass (float) |
| Specify the minimum FOF mass for an SOD halo (default 5.0e12) More...
virtual float | GetMinFOFMass () |
vtkUnstructuredGridAlgorithm * | NewInstance () const |
vtkUnstructuredGrid * | GetUnstructuredGridInput (int port) |
vtkUnstructuredGrid * | GetOutput () |
vtkUnstructuredGrid * | GetOutput (int) |
virtual void | SetOutput (vtkDataObject *d) |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
