void | PrintSelf (ostream &os, vtkIndent indent) |
virtual bool | CanReadFile (const char *fileName) |
void | SetXAxisVariableName (const char *arg) |
virtual char * | GetXAxisVariableName () |
void | SetYAxisVariableName (const char *arg) |
virtual char * | GetYAxisVariableName () |
void | SetZAxisVariableName (const char *arg) |
virtual char * | GetZAxisVariableName () |
vtkStringArray * | GetArrayList () |
bool | InsertLevel (const char *fileName, int level) |
| This function inserts the given file as a resolution level on this reader. More...
int | GetNumberOfLevels () const |
| Gets the number of resolution levels known by this reader. More...
const char * | GetFileNameForLevel (int level) const |
| Gets the filename for the given resolution level. More...
void | RemoveAllLevels () |
| Clears all resolution levels. More...
int | GetNumberOfPointArrays () |
| Returns the number of arrays in the file. More...
const char * | GetPointArrayName (int i) |
| Returns the name of the ith array. More...
int | GetPointArrayStatus (const char *name) |
| Returns the status of the array corresponding to the given name. More...
void | SetPointArrayStatus (const char *name, int status) |
| Sets the status of the array corresponding to the given name. More...
void | SetFileName (const char *fname) |
| Sets/Gets the filename to be read by this reader. More...
virtual char * | GetFileName () |
virtual vtkDataArraySelection * | GetPointDataArraySelection () |
| Get the data array selection tables used to configure which data arrays are loaded by the reader. More...
vtkMultiBlockDataSetAlgorithm * | NewInstance () const |
vtkMultiBlockDataSet * | GetOutput () |
vtkMultiBlockDataSet * | GetOutput (int) |
virtual int | ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
