virtual void | SetSignedDeviations (int) |
virtual int | GetSignedDeviations () |
int | GetNumberOfAttributeArrays () |
| Return the number of columns available for the current value of AttributeMode. More...
const char * | GetAttributeArrayName (int n) |
| Get the name of the n-th array ffor the current value of AttributeMode. More...
int | GetAttributeArrayStatus (const char *arrName) |
| Get the status of the specified array (i.e., whether or not it is a column of interest). More...
vtkInformationIntegerKey * | MULTIPLE_MODELS () |
| A key used to mark the output model data object (output port 0) when it is a multiblock of models (any of which may be multiblock dataset themselves) as opposed to a multiblock dataset containing a single model. More...
virtual int | GetAttributeMode () |
| Set/get the type of field attribute (cell, point, field) More...
virtual void | SetAttributeMode (int) |
void | EnableAttributeArray (const char *arrName) |
| An alternate interface for preparing a selection of arrays in ParaView. More...
void | ClearAttributeArrays () |
virtual void | SetTrainingFraction (double) |
| Set/get the amount of data to be used for training. More...
virtual double | GetTrainingFraction () |
virtual void | SetController (vtkMultiProcessController *) |
| Get/Set the multiprocess controller. More...
virtual vtkMultiProcessController * | GetController () |
virtual void | SetTask (int) |
| Set/get whether this filter should create a model of the input or assess the input or both. More...
virtual int | GetTask () |
vtkTableAlgorithm * | NewInstance () const |
vtkTable * | GetOutput () |
vtkTable * | GetOutput (int index) |
void | SetInputData (vtkDataObject *obj) |
void | SetInputData (int index, vtkDataObject *obj) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
