| vtkPVAMRDualContour () |
| ~vtkPVAMRDualContour () override |
int | RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
void | AddInputCellArrayToProcess (const char *name) |
| Add to list of cell arrays which are used for generating contours. More...
void | ClearInputCellArrayToProcess () |
virtual double | GetVolumeFractionSurfaceValue () |
| Get / Set volume fraction value. More...
virtual void | SetVolumeFractionSurfaceValue (double) |
virtual void | SetIsoValue (double) |
virtual double | GetIsoValue () |
virtual vtkMultiProcessController * | GetController () |
virtual void | SetController (vtkMultiProcessController *) |
virtual void | SetEnableCapping (int) |
| These are to evaluate performances. More...
virtual int | GetEnableCapping () |
virtual void | EnableCappingOn () |
virtual void | EnableCappingOff () |
virtual void | SetEnableDegenerateCells (int) |
virtual int | GetEnableDegenerateCells () |
virtual void | EnableDegenerateCellsOn () |
virtual void | EnableDegenerateCellsOff () |
virtual void | SetEnableMultiProcessCommunication (int) |
virtual int | GetEnableMultiProcessCommunication () |
virtual void | EnableMultiProcessCommunicationOn () |
virtual void | EnableMultiProcessCommunicationOff () |
virtual void | SetEnableMergePoints (int) |
| This flag causes blocks to share locators so there are no boundary edges between blocks. More...
virtual int | GetEnableMergePoints () |
virtual void | EnableMergePointsOn () |
virtual void | EnableMergePointsOff () |
virtual void | SetTriangulateCap (int) |
| A flag that causes the polygons on the capping surfaces to be triagulated. More...
virtual int | GetTriangulateCap () |
virtual void | TriangulateCapOn () |
virtual void | TriangulateCapOff () |
virtual void | SetSkipGhostCopy (int) |
| An option to turn off copying ghost values across process boundaries. More...
virtual int | GetSkipGhostCopy () |
virtual void | SkipGhostCopyOn () |
virtual void | SkipGhostCopyOff () |
vtkMultiBlockDataSetAlgorithm * | NewInstance () const |
vtkMultiBlockDataSet * | GetOutput () |
vtkMultiBlockDataSet * | GetOutput (int) |
virtual int | ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
