void | SetInteractor (vtkRenderWindowInteractor *iren) override |
| Overridden to add interaction observers. More...
virtual vtkRenderer * | GetRenderer () |
| Get the renderer. More...
void | SetEnabled (int) override |
| Overridden to update this->Enabled and hide outline when disabled. More...
void | SetAxesActor (vtkPVAxesActor *actor) |
| Set/get the axes actor to be displayed in this 3D widget. More...
virtual vtkPVAxesActor * | GetAxesActor () |
void | SetParentRenderer (vtkRenderer *ren) |
| Set the renderer this 3D widget will be contained in. More...
vtkRenderer * | GetParentRenderer () |
void | SetVisibility (bool val) |
| Get/Set the visibility. More...
bool | GetVisibility () |
void | SetOutlineColor (double r, double g, double b) |
| Set/get the color of the outline of this widget. More...
double * | GetOutlineColor () |
void | SetAxisLabelColor (double r, double g, double b) |
| Set/get the color of the axis labels of this widget. More...
double * | GetAxisLabelColor () |
void | SetViewport (double minX, double minY, double maxX, double maxY) |
| Set/get the viewport to position/size this 3D widget. More...
double * | GetViewport () |
void | SetXAxisColor (double r, double g, double b) |
| Set the color and visibility of each individual axis. More...
void | SetYAxisColor (double r, double g, double b) |
void | SetZAxisColor (double r, double g, double b) |
void | SetXAxisVisibility (bool vis) |
void | SetYAxisVisibility (bool vis) |
void | SetZAxisVisibility (bool vis) |
void | SetXAxisLabelText (const char *text) |
void | SetYAxisLabelText (const char *text) |
void | SetZAxisLabelText (const char *text) |
vtkInteractorObserver * | NewInstance () const |
virtual void | OnChar () |
int | GetEnabled () |
void | EnabledOn () |
void | EnabledOff () |
void | On () |
void | Off () |
virtual vtkRenderWindowInteractor * | GetInteractor () |
virtual void | SetPriority (float) |
virtual float | GetPriority () |
virtual void | PickingManagedOn () |
virtual void | PickingManagedOff () |
virtual void | SetPickingManaged (bool) |
virtual bool | GetPickingManaged () |
virtual void | SetKeyPressActivation (int) |
virtual int | GetKeyPressActivation () |
virtual void | KeyPressActivationOn () |
virtual void | KeyPressActivationOff () |
virtual void | SetKeyPressActivationValue (char) |
virtual char | GetKeyPressActivationValue () |
virtual vtkRenderer * | GetDefaultRenderer () |
virtual void | SetDefaultRenderer (vtkRenderer *) |
virtual vtkRenderer * | GetCurrentRenderer () |
virtual void | SetCurrentRenderer (vtkRenderer *) |
void | GrabFocus (vtkCommand *mouseEvents, vtkCommand *keypressEvents=NULL) |
void | ReleaseFocus () |
void | On () |
void | Off () |
virtual void | Modified () |
