int | GetSynchronizationMagicNumber () |
| Returned a hash number that can be used to verify that both client and server side are in synch representation wise for delivery. More...
vtkDataObject * | GetPiece (vtkPVDataRepresentation *repr, bool low_res, int port=0) |
| Returns the local data object set by calling SetPiece (or from the cache). More...
vtkDataObject * | GetDeliveredPiece (vtkPVDataRepresentation *repr, bool low_res, int port=0) |
| Returns the data object post-delivery. More...
void | ClearCache (vtkPVDataRepresentation *repr) |
| Clear all cached data objects for the given representation. More...
unsigned long | GetVisibleDataSize (bool low_res) |
| Returns the size for all visible geometry. More...
bool | NeedsDelivery (vtkMTimeType timestamp, std::vector< unsigned int > &keys_to_deliver, bool use_lod) |
| Internal method used to determine the list of representations that need their geometry delivered. More...
void | Deliver (int use_low_res, unsigned int size, unsigned int *keys) |
| Triggers delivery for the geometries of indicated representations. More...
virtual int | GetDeliveredDataKey (bool low_res) const |
| Views that support changing of which ranks do the rendering at runtime based on things like data sizes, etc. More...
void | SetView (vtkPVView *) |
| Get/Set the render-view. More...
vtkPVView * | GetView () const |
void | RegisterRepresentation (vtkPVDataRepresentation *repr) |
| View uses these methods to register a representation with the storage. More...
void | UnRegisterRepresentation (vtkPVDataRepresentation *) |
vtkPVDataRepresentation * | GetRepresentation (unsigned int) |
void | SetPiece (vtkPVDataRepresentation *repr, vtkDataObject *data, bool low_res, unsigned long trueSize=0, int port=0) |
| Representations (indirectly via vtkPVRenderView::SetPiece()) call this method to register the geometry type they are rendering. More...
bool | HasPiece (vtkPVDataRepresentation *repr, bool low_res=false, int port=0) |
vtkAlgorithmOutput * | GetProducer (vtkPVDataRepresentation *, bool low_res, int port=0) |
| Provides access to the producer port for the geometry of a registered representation. More...
vtkInformation * | GetPieceInformation (vtkPVDataRepresentation *repr, bool low_res, int port=0) |
| Set/Get meta-data container for the specific piece. More...
int | GetNumberOfPorts (vtkPVDataRepresentation *repr) |
| Returns number of known port for the representation. More...
virtual void | Modified () |
