virtual int | GetHTGStrategy3D () |
| Get/set the contour strategy to apply in case of a HTG input. More...
virtual void | SetHTGStrategy3D (int) |
virtual void | SetUseImplicitArraysHTG (bool) |
| Set/Get wether or not the filter should use implicit arrays to store the output contour values (stored as point data of the output contour). More...
virtual bool | GetUseImplicitArraysHTG () |
virtual void | UseImplicitArraysHTGOn () |
virtual void | UseImplicitArraysHTGOff () |
vtkContourFilter * | NewInstance () const |
vtkMTimeType | GetMTime () |
void | CreateDefaultLocator () |
void | SetValue (int i, double value) |
double | GetValue (int i) |
double * | GetValues () |
void | GetValues (double *contourValues) |
void | SetNumberOfContours (int number) |
int | GetNumberOfContours () |
void | GenerateValues (int numContours, double range[2]) |
void | GenerateValues (int numContours, double rangeStart, double rangeEnd) |
virtual void | SetComputeNormals (int) |
virtual int | GetComputeNormals () |
virtual void | ComputeNormalsOn () |
virtual void | ComputeNormalsOff () |
virtual void | SetComputeGradients (int) |
virtual int | GetComputeGradients () |
virtual void | ComputeGradientsOn () |
virtual void | ComputeGradientsOff () |
virtual void | SetComputeScalars (int) |
virtual int | GetComputeScalars () |
virtual void | ComputeScalarsOn () |
virtual void | ComputeScalarsOff () |
virtual void | SetUseScalarTree (int) |
virtual int | GetUseScalarTree () |
virtual void | UseScalarTreeOn () |
virtual void | UseScalarTreeOff () |
virtual void | SetScalarTree (vtkScalarTree *) |
virtual vtkScalarTree * | GetScalarTree () |
void | SetLocator (vtkIncrementalPointLocator *locator) |
virtual vtkIncrementalPointLocator * | GetLocator () |
void | SetArrayComponent (int) |
int | GetArrayComponent () |
virtual void | SetGenerateTriangles (int) |
virtual int | GetGenerateTriangles () |
virtual void | GenerateTrianglesOn () |
virtual void | GenerateTrianglesOff () |
void | SetOutputPointsPrecision (int precision) |
int | GetOutputPointsPrecision () const |
vtkPolyDataAlgorithm * | NewInstance () const |
vtkPolyData * | GetPolyDataInput (int port) |
vtkPolyData * | GetOutput () |
vtkPolyData * | GetOutput (int) |
virtual void | SetOutput (vtkDataObject *d) |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
