virtual vtkDataAssembly * | GetDataAssembly () |
virtual void | SetMethodName (const char *) |
| Get/Set the method name to use to get the assembly. More...
virtual char * | GetMethodName () |
void | CopyFromObject (vtkObject *) override |
| Transfer information about a single object into this object. More...
void | CopyToStream (vtkClientServerStream *) override |
| Manage a serialized version of the information. More...
void | CopyFromStream (const vtkClientServerStream *) override |
void | CopyParametersToStream (vtkMultiProcessStream &) override |
| Serialize/Deserialize the parameters that control how/what information is gathered. More...
void | CopyParametersFromStream (vtkMultiProcessStream &) override |
virtual void | AddInformation (vtkPVInformation *) |
| Merge another information object. More...
virtual int | GetRootOnly () |
| Set/get whether to gather information only from the root. More...
virtual void | Modified () |
fetches vtkDataAssembly from a vtkObject subclass
vtkPVDataAssemblyInformation is used to fetch vtkDataAssembly from a vtkObject. The method used to obtain vtkDataAssembly instance is defined by MethodName
and defaults to "GetAssembly".
Definition at line 20 of file vtkPVDataAssemblyInformation.h.
