int | RegisterFilter (vtkAlgorithm *filter) |
| Register a new filter that can be used underneath in the requestData call. More...
void | UnRegisterFilter (int index) |
| UnRegister an existing filter that was previously registered. More...
void | ClearFilters () |
| Remove all the registered filters. More...
int | GetNumberOfFilters () |
| Return the current number of registered filters. More...
vtkAlgorithm * | GetFilter (int index) |
| Return the filter that lies at the given index of the filters registration queue. More...
vtkAlgorithm * | GetActiveFilter () |
| Return the current active filter if any otherwise return nullptr. More...
virtual vtkAlgorithm * | SetActiveFilter (int index) |
| Set the active filter based on the given index of the filters registration queue. More...
vtkMTimeType | GetMTime () override |
| Override GetMTime because we delegate to other filters to do the real work. More...
int | ProcessRequest (vtkInformation *request, vtkInformationVector **inInfo, vtkInformationVector *outInfo) override |
| Forward those methods to the underneath filters. More...
virtual int | ProcessRequest (vtkInformation *request, vtkCollection *inInfo, vtkInformationVector *outInfo) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
