vtkPVExtractComponent Class Reference
Extract a component of an attribute. More...
#include <vtkPVExtractComponent.h>
Inheritance diagram for vtkPVExtractComponent:
Collaboration diagram for vtkPVExtractComponent:
typedef vtkDataSetAlgorithm Superclass
- Public Types inherited from vtkDataSetAlgorithm
enum  DesiredOutputPrecision
virtual void SetInputArrayComponent (int)
virtual int GetInputArrayComponent ()
virtual void SetOutputArrayName (const char *)
virtual char * GetOutputArrayName ()
- Public Member Functions inherited from vtkDataSetAlgorithm
vtkDataSetAlgorithmNewInstance () const
vtkDataObjectGetInput ()
vtkPolyDataGetPolyDataOutput ()
vtkStructuredPointsGetStructuredPointsOutput ()
vtkImageDataGetImageDataOutput ()
vtkStructuredGridGetStructuredGridOutput ()
vtkUnstructuredGridGetUnstructuredGridOutput ()
vtkRectilinearGridGetRectilinearGridOutput ()
vtkDataSetGetOutput ()
vtkDataSetGetOutput (int)
void SetInputData (vtkDataSet *)
void SetInputData (int, vtkDataSet *)
void AddInputData (vtkDataSet *)
void AddInputData (int, vtkDataSet *)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVExtractComponentNew ()
static vtkPVExtractComponentSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkDataSetAlgorithm
static vtkDataSetAlgorithmNew ()
static vtkDataSetAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPVExtractComponent ()
 ~vtkPVExtractComponent () override
- Protected Member Functions inherited from vtkDataSetAlgorithm
 vtkDataSetAlgorithm ()
 ~vtkDataSetAlgorithm ()
vtkDataObjectGetInput (int port)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
int InputArrayComponent
char * OutputArrayName
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkPVExtractComponent Extract a component of an attribute.
Definition at line 18 of file vtkPVExtractComponent.h.
Definition at line 22 of file vtkPVExtractComponent.h.
◆ vtkPVExtractComponent()
vtkPVExtractComponent::vtkPVExtractComponent ( )
◆ ~vtkPVExtractComponent()
vtkPVExtractComponent::~vtkPVExtractComponent ( )
static vtkPVExtractComponent* vtkPVExtractComponent::New ( )
virtual const char* vtkPVExtractComponent::GetClassName ( )
static int vtkPVExtractComponent::IsTypeOf ( const char *  type)
virtual int vtkPVExtractComponent::IsA ( const char *  type)
Reimplemented from vtkDataSetAlgorithm.
static vtkPVExtractComponent* vtkPVExtractComponent::SafeDownCast ( vtkObject o)
void vtkPVExtractComponent::PrintSelf ( ostream &  os,
◆ SetInputArrayComponent()
virtual void vtkPVExtractComponent::SetInputArrayComponent ( int  )
◆ GetInputArrayComponent()
virtual int vtkPVExtractComponent::GetInputArrayComponent ( )
◆ SetOutputArrayName()
virtual void vtkPVExtractComponent::SetOutputArrayName ( const char *  )
◆ GetOutputArrayName()
virtual char* vtkPVExtractComponent::GetOutputArrayName ( )
◆ RequestData()
int vtkPVExtractComponent::RequestData ( vtkInformation ,
vtkInformationVector **  ,
overrideprotectedvirtual
◆ FillInputPortInformation()
int vtkPVExtractComponent::FillInputPortInformation ( int  port,
vtkInformation info
◆ InputArrayComponent
int vtkPVExtractComponent::InputArrayComponent
Definition at line 39 of file vtkPVExtractComponent.h.
◆ OutputArrayName
char* vtkPVExtractComponent::OutputArrayName
Definition at line 40 of file vtkPVExtractComponent.h.
