virtual void | SetController (vtkMultiProcessController *) |
| Get/Set the multiprocess controller. More...
virtual vtkMultiProcessController * | GetController () |
virtual void | SetComponent0 (int) |
| Set/Get the components of interest from the two arrays. More...
virtual int | GetComponent0 () |
virtual void | SetComponent1 (int) |
virtual int | GetComponent1 () |
void | SetComponent (int id, int val) |
int | GetComponent (int id) |
virtual void | SetNumberOfBins (int, int) |
| Set/get the number of bins to be used per dimension (x,y) More...
void | SetNumberOfBins (int [2]) |
virtual int * | GetNumberOfBins () |
virtual void | GetNumberOfBins (int &, int &) |
virtual void | GetNumberOfBins (int [2]) |
virtual void | SetCustomBinRanges0 (double, double) |
| Set/Get whether to use custom bin ranges. More...
void | SetCustomBinRanges0 (double [2]) |
virtual double * | GetCustomBinRanges0 () |
virtual void | GetCustomBinRanges0 (double &, double &) |
virtual void | GetCustomBinRanges0 (double [2]) |
virtual void | SetCustomBinRanges1 (double, double) |
void | SetCustomBinRanges1 (double [2]) |
virtual double * | GetCustomBinRanges1 () |
virtual void | GetCustomBinRanges1 (double &, double &) |
virtual void | GetCustomBinRanges1 (double [2]) |
virtual void | SetUseCustomBinRanges0 (bool) |
virtual bool | GetUseCustomBinRanges0 () |
virtual void | UseCustomBinRanges0On () |
virtual void | UseCustomBinRanges0Off () |
virtual void | SetUseCustomBinRanges1 (bool) |
virtual bool | GetUseCustomBinRanges1 () |
virtual void | UseCustomBinRanges1On () |
virtual void | UseCustomBinRanges1Off () |
virtual void | SetUseGradientForYAxis (bool) |
| Set/Get whether to use the gradient of the scalar array as the Y-axis of the 2D histogram. More...
virtual bool | GetUseGradientForYAxis () |
virtual void | UseGradientForYAxisOn () |
virtual void | UseGradientForYAxisOff () |
virtual void | SetUseInputRangesForOutputBounds (bool) |
| Set/Get whether the output image bounds are obtained from input data array ranges. More...
virtual bool | GetUseInputRangesForOutputBounds () |
virtual void | UseInputRangesForOutputBoundsOn () |
virtual void | UseInputRangesForOutputBoundsOff () |
virtual void | SetOutputOrigin (double, double) |
| Set/Get the output histogram image origin and spacing. More...
void | SetOutputOrigin (double [2]) |
virtual double * | GetOutputOrigin () |
virtual void | GetOutputOrigin (double &, double &) |
virtual void | GetOutputOrigin (double [2]) |
virtual void | SetOutputSpacing (double, double) |
void | SetOutputSpacing (double [2]) |
virtual double * | GetOutputSpacing () |
virtual void | GetOutputSpacing (double &, double &) |
virtual void | GetOutputSpacing (double [2]) |
vtkImageAlgorithm * | NewInstance () const |
vtkImageData * | GetOutput () |
vtkImageData * | GetOutput (int) |
virtual void | SetOutput (vtkDataObject *d) |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
vtkImageData * | GetImageDataInput (int port) |
virtual void | AddInputData (vtkDataObject *) |
virtual void | AddInputData (int, vtkDataObject *) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
