vtkPVFileInformationHelper Class Reference
server side object used to gather information from, by vtkPVFileInformation. More...
#include <vtkPVFileInformationHelper.h>
Inheritance diagram for vtkPVFileInformationHelper:
Collaboration diagram for vtkPVFileInformationHelper:
bool GetActiveFileIsReadable ()
 Returns if this->Path is a readable file. More...
bool GetActiveFileIsDirectory ()
 Returns if this->Path is a directory. More...
virtual void SetPath (const char *)
 Get/Set the path to the directory/file whose information we are interested in. More...
virtual char * GetPath ()
virtual void SetWorkingDirectory (const char *)
 Get/Set the current working directory. More...
virtual char * GetWorkingDirectory ()
virtual int GetDirectoryListing ()
 Get/Set if the we should attempt to get the information of contents if Path is a directory. More...
virtual void SetDirectoryListing (int)
virtual void DirectoryListingOn ()
virtual void DirectoryListingOff ()
virtual int GetSpecialDirectories ()
 Get/Set if the query is for special directories. More...
virtual void SetSpecialDirectories (int)
virtual void SpecialDirectoriesOn ()
virtual void SpecialDirectoriesOff ()
virtual bool GetExamplesInSpecialDirectories ()
 Get/Set if special directories includes the Examples placeholder. More...
virtual void SetExamplesInSpecialDirectories (bool)
virtual void ExamplesInSpecialDirectoriesOn ()
virtual void ExamplesInSpecialDirectoriesOff ()
virtual int GetFastFileTypeDetection ()
 When on, while listing a directory, whenever a group of files is encountered, we verify the type/accessibility of only the first file in the group and assume that all other have similar permissions. More...
virtual void SetFastFileTypeDetection (int)
virtual bool GetGroupFileSequences ()
 Groups file sequences when found. More...
virtual void SetGroupFileSequences (bool)
virtual void GroupFileSequencesOn ()
virtual void GroupFileSequencesOff ()
virtual char * GetPathSeparator ()
 Returns the platform specific path separator. More...
virtual bool GetReadDetailedFileInformation ()
 When off, while listing a directory we skip the expensive fstat call on every file and instead return only their names and basic information about them. More...
virtual void SetReadDetailedFileInformation (bool)
static vtkPVFileInformationHelperNew ()
static vtkPVFileInformationHelperSafeDownCast (vtkObject *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPVFileInformationHelper ()
 ~vtkPVFileInformationHelper () override
virtual void SetPathSeparator (const char *)
char * Path
char * WorkingDirectory
int DirectoryListing
int SpecialDirectories
int FastFileTypeDetection
bool GroupFileSequences
bool ExamplesInSpecialDirectories
bool ReadDetailedFileInformation
char * PathSeparator
When collection information, ProcessModule cannot pass parameters to the information object. In case of vtkPVFileInformation, we need data on the server side such as which directory/file are we concerned with. To make such information available, we use vtkPVFileInformationHelper. One creates a server side representation of vtkPVFileInformationHelper and sets attributes on it, then requests a gather information on the helper object.
Definition at line 24 of file vtkPVFileInformationHelper.h.
Definition at line 28 of file vtkPVFileInformationHelper.h.
◆ vtkPVFileInformationHelper()
vtkPVFileInformationHelper::vtkPVFileInformationHelper ( )
◆ ~vtkPVFileInformationHelper()
vtkPVFileInformationHelper::~vtkPVFileInformationHelper ( )
static vtkPVFileInformationHelper* vtkPVFileInformationHelper::New ( )
virtual const char* vtkPVFileInformationHelper::GetClassName ( )
static int vtkPVFileInformationHelper::IsTypeOf ( const char *  type)
virtual int vtkPVFileInformationHelper::IsA ( const char *  type)
static vtkPVFileInformationHelper* vtkPVFileInformationHelper::SafeDownCast ( vtkObject o)
void vtkPVFileInformationHelper::PrintSelf ( ostream &  os,
◆ SetPath()
virtual void vtkPVFileInformationHelper::SetPath ( const char *  )
This is ignored when SpecialDirectories is set to True.
◆ GetPath()
virtual char* vtkPVFileInformationHelper::GetPath ( )
◆ SetWorkingDirectory()
virtual void vtkPVFileInformationHelper::SetWorkingDirectory ( const char *  )
This is needed if Path is relative. The relative path will be converted to absolute path using the working directory specified before obtaining information about it. If 0 (default), then the application's current working directory will be used to flatten relative paths.
◆ GetWorkingDirectory()
virtual char* vtkPVFileInformationHelper::GetWorkingDirectory ( )
◆ GetDirectoryListing()
virtual int vtkPVFileInformationHelper::GetDirectoryListing ( )
Default value is 0. This is ignored when SpecialDirectories is set to True.
◆ SetDirectoryListing()
virtual void vtkPVFileInformationHelper::SetDirectoryListing ( int  )
◆ DirectoryListingOn()
virtual void vtkPVFileInformationHelper::DirectoryListingOn ( )
◆ DirectoryListingOff()
virtual void vtkPVFileInformationHelper::DirectoryListingOff ( )
◆ GetSpecialDirectories()
virtual int vtkPVFileInformationHelper::GetSpecialDirectories ( )
Off by default. If set to true, Path and DirectoryListing are ignored and the vtkPVFileInformation object is populated with information about special directories such as "My Documents", "Desktop" etc on Windows systems and "Home" on Unix based systems.
◆ SetSpecialDirectories()
virtual void vtkPVFileInformationHelper::SetSpecialDirectories ( int  )
◆ SpecialDirectoriesOn()
virtual void vtkPVFileInformationHelper::SpecialDirectoriesOn ( )
◆ SpecialDirectoriesOff()
virtual void vtkPVFileInformationHelper::SpecialDirectoriesOff ( )
◆ GetExamplesInSpecialDirectories()
virtual bool vtkPVFileInformationHelper::GetExamplesInSpecialDirectories ( )
On by default.
◆ SetExamplesInSpecialDirectories()
virtual void vtkPVFileInformationHelper::SetExamplesInSpecialDirectories ( bool  )
On by default.
◆ ExamplesInSpecialDirectoriesOn()
virtual void vtkPVFileInformationHelper::ExamplesInSpecialDirectoriesOn ( )
On by default.
◆ ExamplesInSpecialDirectoriesOff()
virtual void vtkPVFileInformationHelper::ExamplesInSpecialDirectoriesOff ( )
On by default.
◆ GetFastFileTypeDetection()
virtual int vtkPVFileInformationHelper::GetFastFileTypeDetection ( )
On by default.
◆ SetFastFileTypeDetection()
virtual void vtkPVFileInformationHelper::SetFastFileTypeDetection ( int  )
On by default.
◆ GetGroupFileSequences()
virtual bool vtkPVFileInformationHelper::GetGroupFileSequences ( )
A file sequence could be [foo1.png, foo2.png, foo6.png]. When turned on, the series of files is grouped and our sequence example is named foo..png and original files are discarded from the listing. By default, this flag is set to true.
◆ SetGroupFileSequences()
virtual void vtkPVFileInformationHelper::SetGroupFileSequences ( bool  )
◆ GroupFileSequencesOn()
virtual void vtkPVFileInformationHelper::GroupFileSequencesOn ( )
◆ GroupFileSequencesOff()
virtual void vtkPVFileInformationHelper::GroupFileSequencesOff ( )
◆ GetPathSeparator()
virtual char* vtkPVFileInformationHelper::GetPathSeparator ( )
◆ GetActiveFileIsReadable()
bool vtkPVFileInformationHelper::GetActiveFileIsReadable ( )
◆ GetActiveFileIsDirectory()
bool vtkPVFileInformationHelper::GetActiveFileIsDirectory ( )
◆ GetReadDetailedFileInformation()
virtual bool vtkPVFileInformationHelper::GetReadDetailedFileInformation ( )
Defaults to off. To enable the detailed information like file size and modified time turn this on.
◆ SetReadDetailedFileInformation()
virtual void vtkPVFileInformationHelper::SetReadDetailedFileInformation ( bool  )
◆ SetPathSeparator()
virtual void vtkPVFileInformationHelper::SetPathSeparator ( const char *  )
protectedvirtual
◆ Path
char* vtkPVFileInformationHelper::Path
Definition at line 144 of file vtkPVFileInformationHelper.h.
◆ WorkingDirectory
char* vtkPVFileInformationHelper::WorkingDirectory
Definition at line 145 of file vtkPVFileInformationHelper.h.
◆ DirectoryListing
int vtkPVFileInformationHelper::DirectoryListing
Definition at line 146 of file vtkPVFileInformationHelper.h.
int vtkPVFileInformationHelper::SpecialDirectories
Definition at line 147 of file vtkPVFileInformationHelper.h.
◆ FastFileTypeDetection
int vtkPVFileInformationHelper::FastFileTypeDetection
Definition at line 148 of file vtkPVFileInformationHelper.h.
bool vtkPVFileInformationHelper::GroupFileSequences
Definition at line 149 of file vtkPVFileInformationHelper.h.
bool vtkPVFileInformationHelper::ExamplesInSpecialDirectories
Definition at line 150 of file vtkPVFileInformationHelper.h.
◆ ReadDetailedFileInformation
bool vtkPVFileInformationHelper::ReadDetailedFileInformation
Definition at line 152 of file vtkPVFileInformationHelper.h.
◆ PathSeparator
char* vtkPVFileInformationHelper::PathSeparator
Definition at line 153 of file vtkPVFileInformationHelper.h.
